Author Topic: cylinder and piston question  (Read 2367 times)
Offline aberegg05
« on: May 06, 2014, 09:23:23 PM »
If I put a 68.5mm 86 piston in an 87 cylinder with a long rod crank do I need a spacer plate?
« Reply #1 on: May 07, 2014, 11:52:37 AM »
Quote from: aberegg05;33326
Yes you need a 4.5mm thick spacer plate with a 0.5mm thick base gasket on each side of the spacer plate.
