Author Topic: Axle Bearings  (Read 2834 times)
Offline zcarlson12
Axle Bearings
« on: May 10, 2014, 12:07:19 PM »
How often do you guys grease these? I put in a brand new carrier and bearings this year so it has 4 races (8 motos). Probably 5 total hours.
Offline mx250r91
Axle Bearings
« Reply #1 on: May 10, 2014, 01:00:23 PM »
I think the only ones you can actually grease are the tapered bearings (RAD carrier?). All the others I have seen are sealed bearings.
Offline zcarlson12
Axle Bearings
« Reply #2 on: May 10, 2014, 02:18:34 PM »
http://www.ebay.com/itm/250r-axle-carrier-250r-axle-nut-bearing-housing-and-axle-nut-kit-honda-1987-1992-/261158678738?pt=Motors_ATV_Parts_Accessories&vxp=mtr&hash=item3cce4530d2#ht_2802wt_1312
This is what I bought over the winter. I don't see the tapered bearing anywhere in the description so I guess they are good to go. How would I tell if they need replaced? A scraping noise when I spin the wheels on the jack stand?
Offline 89Longrod
Axle Bearings
« Reply #3 on: May 10, 2014, 02:53:35 PM »
Usually I know the bearings are going bad when there is a side to side play in the carrier. I take the grab bar with the wheels on the ground and pull it side to side. You see right away if there is movement or not and the more movement the closer the bearings are to being shot.
Offline mx250r91
Axle Bearings
« Reply #4 on: May 10, 2014, 04:02:12 PM »
I usually take the axle out and spin the inner races by hand and if they turn rough or notchy, replace them; same goes if they are sloppy loose with a lot of play.
The carrier you linked to is a dual row bearing carrier, not tapered.
Offline zcarlson12
Axle Bearings
« Reply #5 on: May 11, 2014, 07:50:27 PM »
Cool thanks guys. I'll check them out now that I know what to look for.
