Author Topic: ATC250R Front brake assembly!  (Read 1642 times)
Offline JasonB
« on: May 19, 2014, 04:43:05 PM »
this is for a front brake assembly off my 1986 atc250r. This includes the Rotor, master cylinder, brake line, brake liny hardware pirctured, master cylinder lever, and brake rotor, and good brake pads!  This is a fully functioning brake set up for the front of your 85/86 atc250r. There is typical wear and tear and the paint on the reservoir has some typical scratches/wear on it. the casing on the outer plastic is worn as well, but i assure you it works perfectly fine. This includes everything to make your atc250r stop hard up front! looking for 200$ shipped OBO
ATC500R
ATC310R
