Author Topic: pumashine's ftz cylinder  (Read 26708 times)
« Reply #60 on: May 29, 2014, 05:37:25 PM »
Yes you can kick it over in the boot. I think the plug has to be touching ground for that to work?
Best to have someone watch it for you so you can kick it over good. Can see the spark best in dark conditions
Offline patman13mia
« Reply #61 on: May 29, 2014, 07:54:48 PM »
its alive my friends!! cleaned up all the electronics and bam!! second kick
« Reply #62 on: May 29, 2014, 11:46:53 PM »
Quote from: patman13mia;35251
Bet that made you feel pretty relieved!!!!:quad:
Offline patman13mia
« Reply #63 on: May 30, 2014, 11:01:30 AM »
it sure did tony. shitty part of it all though is this lsr swinger i bought off somebody has a slight bend in it so the ride is a lil bumpy. ima take into work and straighten it out on the press. hope it works
« Reply #64 on: May 30, 2014, 11:13:50 AM »
Quote from: patman13mia;35318
:lol: it never ends I tell ya !!!
Offline patman13mia
« Reply #65 on: May 30, 2014, 11:23:07 AM »
yea i know man sucks. and idk why i said swinger.. i meant the axle.
on a good note after the bike kicked over i let it run for 10 mins then shut her down. cooled for about 30 then kicked her over again. then cooled for about 45 mins. then i kicked it again and gave some small blips of the throttle. idled for about 5-10 mins. then i putted down the street in 1st -2nd gear. did that twice on a 3/4 mile road. on the way back to the house i got about half throttle in 3rd-4th gear. that cylinder has some power. more torque than my stock cylinder with mid range porting. i need to get a temp gauge though cause it feels pretty hot. but i dont think its scary hot. i have a fluidye radiator with engine ice in there and a cooler thing on my rad line. should be good enough i would think
« Reply #66 on: May 30, 2014, 07:14:00 PM »
Be careful with letting idle for to long. That bad boy needs air "let it eat". :character0029:
Offline patman13mia
« Reply #67 on: June 01, 2014, 11:10:39 PM »
well i didnt get to ride to much today cause the bike just wouldnt run right at all. when i first started riding the jetting was good with a 50 pilot and 172 main in the 38 a/s carb. after like 1 run it wouldnt idle and kept fouling plugs. i needed a smaller pilot jet but just didnt have it. i even tried multiple needles but nada. ofcourse i i have tons of jets and needles but the smaller pilot jet i need i just didnt have. will buy one on tuesday. i also kept fouling plugs. i mean covered in oil. would the pilot being that rich foul plugs??
« Reply #68 on: June 02, 2014, 12:32:11 AM »
Quote from: patman13mia;35553
When you pull the pilot jet make to see if there is anything in the jet plugging it up. I once had a little piece of rubber come off the fuel line and it was stuck in the pilot jet causing an abnormal amount of smoke. When the carb sits around open to the atmosphere even bugs crawl in. A 50 sounds right but there might be a different explanation.
Offline patman13mia
« Reply #69 on: June 02, 2014, 01:00:16 AM »
yea i looked in there a couple times. i just need to be one size smaller. the bike ran strong once i got into 3rd gear and above. or more than a quarter throttle. i also tried other needles.  i was running ddj in there. its wierd cause when i was doing heat cycles the bike was running awesome down low. i think today was much hotter and also the bike was running much longer than before. i think those two variables may knock me down a jet size?? idk thats all i can think of
« Reply #70 on: June 07, 2014, 10:14:15 AM »
I have only run a DGH here in Oregon.
Offline patman13mia
« Reply #71 on: June 07, 2014, 04:10:00 PM »
i tried that one and its just to fat.
hey tony me and about 10 other friends will be making our way down to oregon to camp and ride the 20-22. hope we can meet up and get some other guys to make it down that weeknd also. we can even start a thread for it
« Reply #72 on: June 07, 2014, 04:16:46 PM »
Quote from: patman13mia;35948
Sounds like a plan. Need to hit OJ up too see where he is at. Did you get anywhere on the jetting today?
Offline patman13mia
« Reply #73 on: June 07, 2014, 04:20:13 PM »
yepp oj and also pnw rider guy!! he wanted to go to. and anybody else from oregon. we will bbqin down there at the camp site so anybody is welcome!!
and i wasnt gona but i think i will now that ya talked me into it. the ppl down the street arent liking me to much any more. but what the hell its 1300 on a sat!! they can �� me!! lol
Offline patman13mia
« Reply #74 on: June 07, 2014, 04:32:35 PM »
just ran it down the road with cel needle in it. ran alot better but need to plug chop that way im not running it to lean ya know
