Author Topic: Water pump replacement tricks?  (Read 8429 times)
Offline TRXforever
« on: May 27, 2014, 10:34:22 AM »
OK fellas, I have replaced my water pump two times and it still leaks (pours) out of the weap hole. This time I have new everything. Bearing, seal, mechanical water pump seal, replacing it ALL! My question is are there any "tricks of the trade", or certain technique that I should know about? Any pointers as to why I may have boogered up $80 worth of water pump seals so far? I am going to attempt this one more time, before I set the thing on FIRE and roll it into the river! ANY help would be greatly appreciated!
Offline PORTED R
« Reply #1 on: May 27, 2014, 10:49:00 AM »
I've only done one waterpump
I had Honda replace the bearing ,oil seal and mc seal
I put the shaft in and impeller and added coolant and ran fine
Also u have to lube up that white seal behind the impeller before install ,I've heard they can burn up or crack on a fresh rebuild
McCoy ProX 350 5mil Duner
« Reply #2 on: May 27, 2014, 10:56:05 AM »
Quote from: PORTED R;35047
Yep, got to put some petroleum jelly on the white ceramic face or the rubber of the mechanical seal. Do you have the washer behind the impeller in there? These often get lost like the ball on the end of the clutch push rod.
« Reply #3 on: May 27, 2014, 01:00:19 PM »
Quote from: Pumashine;35050
I'm getting ready to rebuild my water pump & I'm glad you posted this Tony, otherwise I probably would've ruined it.
Does it matter what kind of petroleum jelly? Is vaseline ok to use?
« Reply #4 on: May 27, 2014, 01:06:49 PM »
Quote from: broken1;35060
Yes Vaseline is the most common. Other brands are the same but less expensive.
Offline TRXforever
« Reply #5 on: May 27, 2014, 01:22:30 PM »
I do have the #11 infamous tiny lost washer in place!
Offline TRXforever
« Reply #6 on: May 27, 2014, 01:24:13 PM »
But I did not lube the white face...that sounds pretty bad! When I took the last one out, I could not see any defects in the non-jellied seal. I will be sure to lube this one.
« Reply #7 on: May 27, 2014, 01:32:32 PM »
Are you using OEM seals? Maybe take a pic of the set up to see if there is something your missing? after installation there should be a slight tension when you spin the WP shaft. The spring pressure of the mechanical seal is pushing against the white ceramic piece. The white ceramic piece is encased in a rubber sleeve. Just hard to understand why its pouring out. Did you run it for awhile to see if the leak stopped?
Offline TRXforever
« Reply #8 on: May 27, 2014, 02:49:23 PM »
Yes I was running the first heat cycles for break in, and it pissed a little over half the engine ice out of the weap hole (into a gatorade bottle via nifty funnel). It actually got a little worse as the temp was climbing. I shut it down before it got all the way to temp, threw a wrench or two, said a few swear words, snapped open a cold one and called it a night! Installed the SECOND complete kit a few days later, same senario! Now I have the THIRD complete kit with bearing this time! Going to install tomorrow or thursday evening.
« Reply #9 on: May 27, 2014, 03:22:11 PM »
Are you taking the clutch cover off or doing this on the bike? I replace all bearings and seals when doing a rebuild of the WP.
Offline TRXforever
« Reply #10 on: May 27, 2014, 03:41:44 PM »
Clutch cover off....always! Kind of difficult to press the "tin plate" of the mechanical seal evenly.
Offline TRXforever
« Reply #11 on: May 27, 2014, 03:42:25 PM »
I did not replace the bearing on the first two, but everything else got replaced, hope the lube is the key!
Offline PORTED R
« Reply #12 on: May 28, 2014, 12:39:18 AM »
What style impeller are you running
I know on 85 to 87 the impeller is seperate from the cap nut with a copper washer
Maybe the copper washer is bad or waterpump shaft itself is worn beyond tolerance
Offline Bio86
« Reply #13 on: May 29, 2014, 11:44:14 AM »
Any coolant in the oil?  Coolant system isn't being over-pressured from a head gasket issue is it?
McCoy\'d
Offline TRXforever
« Reply #14 on: May 29, 2014, 04:45:24 PM »
No coolant in the oil, head gasket good! Putting new complete water pump in tonight, fingers are crossed.
