Author Topic: Should I swap front ends?  (Read 10232 times)
Offline sdxp787
« Reply #15 on: October 09, 2014, 12:58:35 PM »
I want to use the 04-05 spindle/hub upgrade on my 86R.  I am looking for performance gains as I race XC.  Is this a gain or no?  I also want to use the newer 450R brake calipers and rotors.  The 450R brake setup is so much better, in my opinion, than the 250R.  Lots of effort to pull the lever on the 250 and virtually no effort on the 450.  this is what is making me want to switch.  Any opinions?  Why arms would I use with the 450 spindles?
2013 IXCR Senior B Class Champion
2007 TRX450R XC ready
2006 TRX450ER XC ready
1986 TRX250R (XC build in progress)
2007 Honda Rancher
2007 Yamaha Wolverine 450
1998 Suzuki LT80
1984 Yamaha PW50
2004 Honda R12X
1996 SeaDoo XP
Offline andy@maultechatv
« Reply #16 on: October 10, 2014, 07:12:16 AM »
How about some pictures for explanation and food for thought.  Here is a Walsh chassis with 86 spindles and hubs.  Notice how bad the bump steer is.  Now keep in mind that the chassis manufacturer and steering stem flag height also play a huge factor in this but I'm just showing you what you don't want.  The toe at full shock extension was set perfectly straight.  We did not change spindles on this bike to see if it helped out.
« Reply #17 on: October 10, 2014, 09:08:26 AM »
Quote from: andy@maultechatv;44300
Wow that's tells the whole story right there. What would you have done to remedy this problem Andy?
Looks like I need to take a look at this on my bike
« Reply #18 on: October 10, 2014, 10:18:14 AM »
Quote from: Tbone07;44309
First I would change the tie rod end heights.  Then I would try a different spindle setup to see if it helped.  And if neither of those were significant enough I would change the steering stem flag height.
Offline Burns363R
« Reply #19 on: October 10, 2014, 10:35:24 AM »
Stem flag height seems to be the weak point on the R from my experience.
