Author Topic: Squish and Band Width Check  (Read 3545 times)
Offline Bio86
« on: June 01, 2014, 06:59:39 PM »
I'm messing with a motor out of an 88 I picked up, has a 73mm piston stock cylinder with what says a 22cc dome. Using .062 solder getting .035" at the cylinder wall with a width of like .525" on the dome side.  Does that seem correct?  I have no clue what the porting is and haven't degreed one before to know where it's at.  Just looking for some guidance there, afraid to throw fuel in it and have it detonating real bad right off the bat.   Haven't done a compression check yet.
Any thoughts?
McCoy\'d
Offline Bio86
« Reply #1 on: June 19, 2014, 08:28:33 AM »
Ended up throwing it together.  It has 210psi with non-seated rings.. that's 110-112 fuel territory correct?
McCoy\'d
Offline patman13mia
« Reply #2 on: June 19, 2014, 08:47:40 AM »
yepp i would just run 110 anyways!! way better for your engine
« Reply #3 on: June 19, 2014, 11:02:09 AM »
Has your dome been machined for your bore size?
Offline Bio86
« Reply #4 on: June 19, 2014, 11:19:47 AM »
Yeah it has, the flat surface lined up nice with the top cylinder face around the bore.
McCoy\'d
