Author Topic: trx5b on a OEM cylinder  (Read 2825 times)
Offline trx250scar
« on: June 03, 2014, 03:10:29 PM »
Is there enough difference to make the 5"b" not perform Well with an OEM cylinder or smaller bore than my 330? I am considering an OEM cylinder or just buying a complete used engine. Don't want my pipe to not perform as good as it should being that it is a 5b. I honeslty don't even no What the difference is between a 5 and a 5b. Something for the big bore Motors but it doesn't seem to b in the stinger and tail sections.
Offline Redrider9982
« Reply #1 on: June 04, 2014, 05:04:50 AM »
I think the only thing different in the pipe is just where the silencer slips on its a little bit bigger cuz to flow a little more through the pipe , you should be fine running the 5b on an oem cylinder
« Reply #2 on: June 04, 2014, 07:28:29 AM »
stinger size is the same on the B esr pipes, the only difference is the header diameter. it may affect your powerband, maybe not, but if you know you arent going back to a big bore anytime soon just sell it and get a small bore pipe. there is always ppl looking for those pipes.
