Author Topic: Looking for Pics of how people Bolt up Stock rear fender brace/bar to maier rears  (Read 5568 times)
Offline TatTooL23
I have a set of Maier rear fenders, and have the OEM rear fender brace bar. i just would like to c how people are attaching it to the lower rear fenders. i know they come with "L" brackets, but i guess u have to drill ur own holes. just curious. help me out. thanks
RNS Powdercoating
FSU Powersports
AFS Racing
TPC Trikes
Offline mx250r91
Here's mine. This is the left side. Excuse the dirt.
Offline Sky
I had such a hassle with mine I left them off. The Maier are strong enough and reinforced in the seam that i just left it off.
Offline mx250r91
I found the bracket really helps keep the fenders off the exhaust and from melting when they get weighed down with a ton of mud and when jumping.
Offline 2strokesforever
I have Pro Circuit pipe and Silencer dont run the fender brace and that kind of pipe setup doesnt ride on fender
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
Offline TatTooL23
got them on. worked fine. here r some pics
[ATTACH=CONFIG]743[/ATTACH][ATTACH=CONFIG]744[/ATTACH][ATTACH=CONFIG]745[/ATTACH][ATTACH=CONFIG]746[/ATTACH][ATTACH=CONFIG]747[/ATTACH][ATTACH=CONFIG]748[/ATTACH]
RNS Powdercoating
FSU Powersports
AFS Racing
TPC Trikes
Offline mx250r91
Looks good!
Looks good man
Offline TLR-Online
Maier also sells "heat tiles" to help protect the plastics from the silencer: https://www.maier-mfg.com/catalog/6-x-12-heat-tile-kit
Didn't know maier made that! Thought I would share what I used. 25$ for 2 12"×12" pieces. So far so good...
Well where'd the pic go??
« Last Edit: January 11, 2014, 06:37:22 PM by sameltoe »
