Author Topic: New PEP rear vs OEM PEP conversion - suggestions, pros, cons.  (Read 5678 times)
Offline bnau267
The price to convert and setup my OEM as a PEP is around $450.  My guess is another $350 to $400 gets me a brand new PEP rear.  Who's been down this road?  I have Axis for the most part, and they seem like a better priced suspension, but I'd like to run PEPs on the bike I'm currently building.  I'd have Baldwin do the PEP setup being that they're next door and Mark has a ton of R background.
Thanks, Bob
« Last Edit: June 10, 2014, 07:48:27 AM by bnau267 »
Offline zcarlson12
« Reply #1 on: June 08, 2014, 05:28:23 PM »
I've been sending Baldwin my suspension for years and never have had a complaint. I run ZPS fronts and an Axis no-link rear on my Laeger which he just revalved and serviced, they are perfect.
Offline andy@maultechatv
« Reply #2 on: June 08, 2014, 05:48:09 PM »
I'd keep the Axis.  They are better.  There's nothing wrong with the stock internals either if they are changing them.  You may just be buying new springs and a revalve.
Offline bnau267
« Reply #3 on: June 08, 2014, 06:36:14 PM »
Quote from: andy@maultechatv;36044
Thanks Andy.  Not doubt I'm a fish out of water when it comes to suspension.  The problem with my Axis set is that I need to have mine converted from LT to standard to work with the Roll XC arms.  Plus I was wanting to go piggy back and PEP has a cool little kit to connect the bottle.
« Reply #4 on: June 08, 2014, 06:42:22 PM »
We have the same mounts for Axis too!  I'm not a paying site sponsor and am not trying to do business on here.  Just wanted to help out and tell you it would be better to stick with the Axis.  To go to long travel on the Axis you will need new bodies which isn't that big of a deal for a shop to do.
Offline bnau267
« Reply #5 on: June 08, 2014, 07:10:58 PM »
Quote from: andy@maultechatv;36046
Thanks for your insight.  I appreciate it very much.
Offline Leftynanners
« Reply #6 on: June 10, 2014, 02:49:05 AM »
Just out of curiosity, what advantages could somebody expect purchasing an aftermarket shock as opposed to doing a conversion on their stock shock?
« Reply #7 on: June 10, 2014, 07:51:24 AM »
Quote from: Leftynanners;36198
That's a really good question.  Actually some stock fronts have really good pistons in them.  But the downfalls to them are that the adjusters don't have much range and some don't do anything at all.  The other big factor with stock shock conversions is that they are limited to what extended and compressed lengths they can be changed to.
Offline big_R_bore
« Reply #8 on: July 15, 2014, 11:57:04 AM »
I just had my 86 rear shock converted with pep internals from Baldwin motorsports, I can give feedback soon when I finish the build here in the next month, but I have never riden on a true pep rear shock so I cant compare the two.
« Reply #9 on: July 15, 2014, 01:27:47 PM »
This might be another option as well. Maul Tech is now the exclusive dealer for GT Suspension components. If I didn't have an almost new set of Axis shocks, I would be buying a set of these from Andy.
« Reply #10 on: July 15, 2014, 02:23:07 PM »
Quote from: zcarlson12;36042
Why do you prefer the Axis over the PEP, Andy?
« Reply #11 on: July 15, 2014, 02:34:52 PM »
Check ball system.
« Reply #12 on: July 15, 2014, 02:42:59 PM »
Quote from: Burns363R;39091
Check ball system.
This ^^^^
« Reply #13 on: July 15, 2014, 07:57:41 PM »
There is a reason PEP didn't run a check ball piston in the rear shock.  Because it won't work!
