Author Topic: DG pipe opinions?  (Read 9232 times)
Offline supernutt
DG pipe opinions?
« on: June 11, 2014, 09:16:59 PM »
Picked up a quad and it came with a DG pipe and silencer.  Going for an OEM look.  I would like to use this pipe.  Are these decent pipes or is it scrap metal?  It would look similar to oem and that is a big plus for me.  My cylinder is ported so I can't run the stock pipe.  Currently have an old Paul Turner TRX race on it and that doesn't run too bad but not the look I am going for.  Thanks.
DG pipe opinions?
« Reply #1 on: June 11, 2014, 09:37:17 PM »
Well I am sure people will say it's a piece of junk, people also say this about the FMF and I am running one. Yeah the DG won't be optimum, but it is pretty easy to change the pipe out and try it. If you like it great, if not change it to something else.
Offline supernutt
DG pipe opinions?
« Reply #2 on: June 11, 2014, 09:39:48 PM »
Kind of my thoughts.  I see I could still buy it new if i wanted to.  It doesn't sound too popular though.
Offline kb250r
DG pipe opinions?
« Reply #3 on: June 11, 2014, 10:34:40 PM »
Popular no!! But if it pulls and hits where you need it to for yor application then so be it, dg it is....
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
Offline Onski326
DG pipe opinions?
« Reply #4 on: June 12, 2014, 09:16:18 AM »
Can't speak for the pipe but I have a DG silencer on my bike with a CT pipe and really like it. Has a good sound to it. Straight flow through design.
\'08 Suzuki RM-Z250
\'05 Honda CRF250R
\'05 Honda TRX450R
Onski Powersports
Offline atvmxr
DG pipe opinions?
« Reply #5 on: June 12, 2014, 10:16:45 AM »
so much fail in this thread....   :tan:
carry on
Offline kb250r
DG pipe opinions?
« Reply #6 on: June 12, 2014, 11:09:17 AM »
Quote from: atvmxr;36400
carry on
 Please Explain pipe master, if a pipe works good for somebodys application why shouldnt they use it no matter the brand
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
DG pipe opinions?
« Reply #7 on: June 12, 2014, 11:17:14 AM »
carry on
Please educate then oh great one. I don't see you adding anything to the conversation.
DG pipe opinions?
« Reply #8 on: June 12, 2014, 11:24:00 AM »
I believe the DG pipe is an OEM replacement or comes quite close to the stock feel. My sister and brother in-law swear by that pipe. They have one on each of their 3 R's. 100% stock other than reeds and FMF silencer.
Offline atvmxr
DG pipe opinions?
« Reply #9 on: June 12, 2014, 11:34:51 AM »
Quote from: supernutt;36367
not necessarily true, not optimal, but you can use the stock pipe and silencer if you wanted to.
Going for an OEM look.  I would like to use this pipe.    It would look similar to oem and that is a big plus for me.   Currently have an old Paul Turner TRX race on it and that doesn't run too bad but not the look I am going for.
as for DG, their pipes mimic OEM bends and shape- therefore the performance should be similar to stock.  I have no idea why you would want an "OEM" look to the pipe.  If its a stock showroom peice put an OEM on there and let it sit there in a corner, if its a rider spend a little money and get a good performing pipe for it.
Quote from: Rupp250;36369
just because you use it doesnt change the fact its crap compared to a LRD or Sparks - for example
Quote from: Onski326;36394
Can't speak for the pipe but I have a DG silencer on my bike... Straight flow through design.
all silencers are straight through design
Now having said all that, Im grumpy and havent had my coffee yet.  If you happy with it then whatever, good for you.  at least you are riding and riding a 250r.
as I said - carry on
:surprise:
Offline Onski326
DG pipe opinions?
« Reply #10 on: June 12, 2014, 11:55:41 AM »
Turn down
Straight.
I've read on this site and the other site that the turn down hurts performance. Sorry if I was misinformed. I didn't want to offend anyone or put any bad info out there.
\'08 Suzuki RM-Z250
\'05 Honda CRF250R
\'05 Honda TRX450R
Onski Powersports
Offline atvmxr
DG pipe opinions?
« Reply #11 on: June 12, 2014, 12:22:10 PM »
we are piddling over nothing, but you are discussing the end cap, either way the flow is "straight through" the silencer.
DG pipe opinions?
« Reply #12 on: June 12, 2014, 12:38:52 PM »
Just because it is "crap" to you, doesn't mean it is crap to someone else. Many people run everything stock as well. To me those Sparks or LRD pipes are crap because they were not built to my motor designs.
DG pipe opinions?
« Reply #13 on: June 12, 2014, 12:51:30 PM »
Back in the day I had a coffmans and an fmf that were routed like a stocker and the dg. If you like that look you could even possibly mount a stock heat shield to them. Not the best pipes normally but...
DG pipe opinions?
« Reply #14 on: June 12, 2014, 01:03:29 PM »
Tim Farr used to be a big DG rider. Dunno if he used the pipes but he definitely used the silencers
