Author Topic: cr 250 flywheel weights  (Read 4234 times)
Offline kidder86
« on: June 15, 2014, 11:17:31 AM »
anyone here have any experience with these flywheel weights? wondering how much difference they make and what weight is better? and how well they stay on ? and have they come loose after installed?
thanks
« Reply #1 on: June 15, 2014, 11:28:19 AM »
Seems these are riveted on?
 Stock flywheel
« Reply #2 on: June 16, 2014, 09:13:55 AM »
What brand is that weight? Anyone try Steahly or Msr? Can the trx cover handle a larger diameter weight?
« Reply #3 on: June 16, 2014, 10:11:04 AM »
stealthy weights fit under the stock cover.
« Reply #4 on: June 16, 2014, 10:42:53 AM »
I might try one of those. I presume the trx cover has more room than a cr cover that those are designed for.
« Reply #5 on: June 16, 2014, 10:52:20 AM »
a 16 oz fits with no issues
« Reply #6 on: June 16, 2014, 10:57:21 AM »
Quote from: rsss396;36837
Have you found these to help in riding?
« Reply #7 on: June 16, 2014, 11:53:56 AM »
These are the ones I'm considering 12 or 14oz http://www.steahlyoffroad.com/honda-flywheels/90-01-honda-cr250r-flywheel-weight.html. I'm not sure if the pics are correct is it held on by the flywheel nut or is it attached to the flywheel?
« Reply #8 on: June 16, 2014, 11:57:55 AM »
this was not on my bike, but on a family member"s bike and he liked it, said it was easier to start from a dead stop in the sand and seamed to make the bike act like it pulled more by slowing engine acceleration. I will probably steal it and give it a try on my stock 88 when I change the ignition to a cr125 box and 250 stator/flywheel
« Reply #9 on: June 16, 2014, 11:59:04 AM »
Quote from: rk88r;36845
those are exactly the style we used
« Reply #10 on: June 16, 2014, 12:06:56 PM »
My little bit of installation advice is to put your flywheel nut on the bike and slightly over tighten the nut than factory specs call for.
Remove the nut and pretty sure the washer, then install the weight using the tool, then tighten the set screws just a little.
loosen the set screws and take the flywheel weight off, now look at the flywheel were the set screws tighten and make sure that they are fully seating on the center hub part of the flywheel, its really hard to explain until you actually install one to see what I mean. I am almost sure we had to remove the washer to allow the set screws to grab better on to the center hub's edge.
Over tightening the factory nut and removing it before installing the weight helps seat the flywheel real good so you do not shear a flywheel key.
« Reply #11 on: June 16, 2014, 12:47:56 PM »
Awesome Dave thanks for the info.
Rick
