Author Topic: My new motor  (Read 7547 times)
Offline Mickkey82984
My new motor
« on: June 16, 2014, 11:13:13 AM »
I few pics of my new motor. Just got to stuff it in my stock frame and get a wheelie bar made, I don't think +8 is going to be enough.
Offline zcarlson12
My new motor
« Reply #1 on: June 16, 2014, 11:25:12 AM »
Looks sick! Hope you like hanging on for dear life.
My new motor
« Reply #2 on: June 16, 2014, 11:33:48 AM »
Oh yeah!  Specs?
:nitro:
My new motor
« Reply #3 on: June 16, 2014, 11:47:08 AM »
Make sure you take pics of the front end for your riding buddies, cause they're only seeing the back.
Offline Bigred
My new motor
« Reply #4 on: June 16, 2014, 12:04:02 PM »
Or the bottom as he's wheeling by lol
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
My new motor
« Reply #5 on: June 16, 2014, 01:22:02 PM »
Quote from: havinnoj;36843
Oh yeah! Specs?
:nitro:
Its a 97mm saber top end drag ported by Hybrid, 77mm balanced cr 500 crank, cr 250 ignition, 1-4 override back cut by pete, direct drive lock up, SCP off drag pipe, running on Alky. Just have to get a pingel, fuel pump and a moster carb to feed this beast.
My new motor
« Reply #6 on: June 16, 2014, 01:45:13 PM »
Quote from: Mickkey82984;36858
Looks familiar. Is that a UPP intake manifold?
My new motor
« Reply #7 on: June 16, 2014, 01:54:08 PM »
I'm pretty sure it is but I will have to ask bill to be sure.
My new motor
« Reply #8 on: June 16, 2014, 02:06:46 PM »
Quote from: Mickkey82984;36860
Traxman was saying all his UPP intake manifolds used with alcohol fell apart in the last couple years. He showed me 2 of them a couple weeks ago. The polyurethane has separated from the aluminum inside.  Just a heads up if it turns to silly putty! The gas motors don't have this problem
My new motor
« Reply #9 on: June 16, 2014, 04:14:26 PM »
Quote from: Pumashine;36863
Thanks for the info, this will be the one of first thing I check when It arrives.
Offline Morse250r
My new motor
« Reply #10 on: June 16, 2014, 05:13:10 PM »
I've never had an issue with upp and alky
88 rb racing duner
Trx 70\'s
Atc 125
My new motor
« Reply #11 on: June 16, 2014, 11:02:37 PM »
Nice build Mickkey!
on the UPP boots I had a issue with a couple saber/liger boots falling apart but I really do not think alcohol was the problem
the very first boot I had was the typical style UPP boot being very thick and stiff. When I was widened the inside of it I ground the rubber back far enough on one side to expose the aluminum plate. Everything was fine until the end of the season when the rubber started to delaminate from the alum plate causing a small intake leak.
so I ordered 2 new intakes just to have a spare, both these new intakes were very different than the first boot any other UPP boot.
these new boots were much softer and thinner than the first, I actually like the look and feel of them because of the better vibration isolation for the carb.
well after only 1 day at the Dyno which was about 50 pulls I found that the boot had torn this time but was bonded to the alum plate.
i was racing the next weekend so I threw the spare on and crossed my fingers that it would hold up will it did for about a day and part of another before it also was torn.
so after that I talked with cp and they credited me for them and I actually switched to the oval style they stocked for the oval CPC carbs since I was running a 52 and 56 carb it fit tight enough and has been very durable.
If CP sends you the thinner softer rubber style send them back or they will fail very quickly.
Offline atv fan 28
My new motor
« Reply #12 on: June 16, 2014, 11:12:13 PM »
I got a spare UPP manifold when I bought my Saber and it fell apart before I ever used it. But it had been used by the previous owner. I use the oval shaped manifold now and it seems to be holding up well even thought it only has 3 trips out on it
My new motor
« Reply #13 on: June 16, 2014, 11:15:28 PM »
Was the boot that fell apart a typical thick UPP style like your oval boot?
Offline atv fan 28
My new motor
« Reply #14 on: June 16, 2014, 11:26:38 PM »
it was more of a rubber type material. The one I'm using now is more shiney and slick if that makes sense....
« Last Edit: June 16, 2014, 11:36:41 PM by atv fan 28 »
