Author Topic: Where to mount the shock reservoir  (Read 5850 times)
Offline Pj Uptmor
« on: July 05, 2014, 10:17:14 AM »
I am trying to find a location to mount the front shocks reservoirs.  I kno on the front frame is there any other places. If do can you post pictures.  Thank you
« Reply #1 on: July 05, 2014, 10:38:00 AM »
On the side of the frame right behind the radiator is the next location I am doing.
Offline Pj Uptmor
« Reply #2 on: July 05, 2014, 10:59:55 AM »
Thank you Tony on the quick reply. Can you take a picture of the oil going over the radiator. Did you cut the shrouds ?
« Reply #3 on: July 05, 2014, 11:33:03 AM »
Quote from: Pj Uptmor;38392
Mark Myers sent me this pic to show where he wanted the rezi's located. I was just showing a location. I have also seen them going straight back towards the motor. I will make an effort to make them fit either way when in the programing stage.
Offline Pj Uptmor
« Reply #4 on: July 05, 2014, 12:06:21 PM »
My oil lines can go over the radiator but they are short and be rubbing on the radiator hose. I thought about before the radiator by the steering stem. Just looking at my options Thank you  Paul
« Reply #5 on: July 05, 2014, 02:09:20 PM »
Quote from: spiritaces;38395
Mine are up front. I'll get a pic in a bit
Here a pic of Jon's before the bike left
« Reply #6 on: July 05, 2014, 07:00:14 PM »
I mount mine is the same location.
Offline Pj Uptmor
« Reply #7 on: July 06, 2014, 11:28:15 AM »
To run the rezi back of the radiator do you have a longer oil line .
Offline TRXforever
« Reply #8 on: July 06, 2014, 04:26:17 PM »
I mount mine up front with Tony's holders.
Offline Pj Uptmor
« Reply #9 on: July 06, 2014, 04:48:05 PM »
Thank you for your input
Offline ytman
« Reply #10 on: July 06, 2014, 09:15:21 PM »
If you don't need to adjust them while you are riding....I would say in front of any heat source. Radiator, Exhaust, Motor,....Fronts right? If you don't have long lines , frame tubes in front of the radiator are best....or
Offline Farmboy1979
« Reply #11 on: July 06, 2014, 09:17:00 PM »
That photo was actually the rear shock rezzy, not the front. It's located there per Elka instruction.
Offline andy@maultechatv
« Reply #12 on: July 15, 2014, 07:59:49 PM »
Put piggyback clamps on them.
