Author Topic: 400ex Hub Setup  (Read 10020 times)
Offline bholzgen
400ex Hub Setup
« on: July 11, 2013, 10:59:00 PM »
I have lonestar +2 a-arms with factory spindles.  The ball joints are adjusted as far as they can go, and there is still too much negative camber.  I was told 400ex spindles fix this issue?  If so I would be interested in buying a 400ex front end setup.
Thanks, Blake
« Last Edit: July 11, 2013, 11:12:27 PM by bholzgen »
2002 Roll Design Lobo MX
2002 Laegers CRF450R Hybrid
1985 ATC 70
Offline mx250r91
400ex Hub Setup
« Reply #1 on: July 11, 2013, 11:07:26 PM »
Hubs won't change your camber but the spindles will...
Offline bholzgen
400ex Hub Setup
« Reply #2 on: July 11, 2013, 11:12:46 PM »
I am aware, I typed that incorrectly.
1985 ATC 70
Offline mx250r91
400ex Hub Setup
« Reply #3 on: July 11, 2013, 11:39:30 PM »
Ahh sorry there. I believe the 04-05 450R spindles work as well and utilize twin piston calipers.
400ex Hub Setup
« Reply #4 on: July 14, 2013, 10:47:33 AM »
Quote from: mx250r91;3072
The 06+ work well also. :encouragement:
Offline mx250r91
400ex Hub Setup
« Reply #5 on: July 14, 2013, 11:50:32 AM »
Quote from: F-Red;3667
Good to know! For some reason though the 04-05 sticks in my mind as being more desirable?
Offline bholzgen
400ex Hub Setup
« Reply #6 on: July 14, 2013, 12:02:04 PM »
What should I expect to pay for a mint set?
1985 ATC 70
400ex Hub Setup
« Reply #7 on: July 14, 2013, 12:54:14 PM »
I have a set  Im not using don't know what there worth .shipping from dan would be cheaper
400ex Hub Setup
« Reply #8 on: July 15, 2013, 12:57:53 PM »
Quote from: mx250r91;3672
I do believe the 04-05 have a better turning radius. Not 100% positive on that. Better geometry, in some area. My type of open trail and woods riding, doesn't require that advantage.
Quote from: bholzgen;3673
For an 07 TRX450R, I paid $150.00 for everything needed.
Offline JoePA
400ex Hub Setup
« Reply #9 on: July 17, 2013, 02:16:37 PM »
I have a set of 400ex spindles at the house somewhere. I'll look for them if you are interested. it's just the spindles...no hubs or calipers.
Offline nastyracing
400ex Hub Setup
« Reply #10 on: August 02, 2013, 04:04:40 PM »
pm being sent I got what you need
400ex Hub Setup
« Reply #11 on: August 02, 2013, 09:43:37 PM »
Don't forget you can use the yfz calipers (dual piston) with the 400ex stuff. I got a fresh black pc set of 400 hubs if you piece it together...cheap.
Offline lrd_250r
400ex Hub Setup
« Reply #12 on: August 03, 2013, 11:27:11 AM »
I just put the 06 trx450r front end on. I had leftover 450r parts and i didnt want to buy parts
Offline bholzgen
400ex Hub Setup
« Reply #13 on: August 04, 2013, 01:48:44 PM »
Purchased a set from Dan Hung.  Thanks for the help guys!
However after installing the new 400ex front end parts I still have negative camber.  Come to find out, 3 of the four ball joints on my +2 LSR arms are short.  One is longer, allowing the camber to be where I want it.  Does anyone have a longer upper ball joint?  I have no idea what kind of ball joints they are either... I will try to get photos.  Going to need help with this one guys!
1985 ATC 70
Offline bholzgen
400ex Hub Setup
« Reply #14 on: August 04, 2013, 01:56:10 PM »
Here is a photo.  I can post better photos of the ball joints if needed.
1985 ATC 70
