Author Topic: Well, if the wife finds out I'm dead...  (Read 11645 times)
Offline Snowmaker10
« on: July 16, 2014, 06:35:23 PM »
I decided I'd better start building this 330pv jug I've had laying around for a while. Picked up a set of clean 89 cases to help  get the ball rolling.  I also just ordered a full set of oem Honda case bearings and a few oil seals I dont already have.  I already have all the trans which I'd like to get cryo treated and I have an oem crank I'd like to have all welded up. My only question is, to go +4mm or not?  I'm still debating or if I'll just got long rod stock stroke. What do you guys think?
Offline DnB_Racing
« Reply #1 on: July 16, 2014, 06:56:37 PM »
if you go +4 you will need to get the cylinder ported for the additional stroke..
it really depends on what the cylinder was originally setup for. And how much you want to spend
Offline wretched73
« Reply #2 on: July 16, 2014, 07:10:03 PM »
If you go +4 you might as well get a puma cylinder.... :hyp:
Offline Snowmaker10
« Reply #3 on: July 16, 2014, 07:30:19 PM »
I do realize that the porting will have to be setup for +4 crank.  The jug is unported at this time and since I already have this jug on the stock bore and what you see sitting in the picture cost me 375$ to my door I'll continue with this prox jug.
Offline Grande huevos
« Reply #4 on: July 17, 2014, 09:33:47 PM »
Douglas what's up man !!! Glad to see your building that bad boy !! If it were me man I'd just get a nice port job for that thing.. I don't know if you've ridden a 330 before but I think you would be pleased with the power output it has especially being a PV.   I hope you have this running the next time I see you guys
Offline Snowmaker10
« Reply #5 on: July 17, 2014, 09:50:47 PM »
Quote from: Grande huevos;39294
Hell yeah Jake!  I should have this things running this fall.  I am buying a house this winter so it's gonna be a slow going deal. Plus, snowmobile season is approaching and I also am playing with that.  I have not ridden a 330 but think I will just stay with the stock stroke. I'll probably have the crank all welded as my main priority with this build isn't really power as much as it being bulletproof.  I'm pretty excited about it.
Offline Daniel370r
« Reply #6 on: July 17, 2014, 09:51:47 PM »
I would do a stroker or short rod, IMO from the quads I have rode with short rods are real snappy compared to long rods.good luck on your build the Rotex power valves are great.
Offline Snowmaker10
« Reply #7 on: July 17, 2014, 10:50:36 PM »
Daniel, I have a short rod and a long rod motor and you can tell that the short rod revs quicker. I do like it and have debated just running it as that. Now you have me thinking damnit! Lol.
Offline kb250r
« Reply #8 on: July 17, 2014, 10:50:36 PM »
stoke it man!!! You'll never miss a couple more hundred.....hehe
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
Offline Snowmaker10
« Reply #9 on: July 17, 2014, 10:51:37 PM »
Quote from: kb250r;39302
Hahahaha!  Ya, for sure!  Thank god bill gates is my uncle. Lol
« Reply #10 on: July 18, 2014, 12:39:04 AM »
Nice stand...go 4 mil. Does not cost any extra.
Offline mennis1971
« Reply #11 on: July 18, 2014, 07:43:02 AM »
I'd either go short rod for revs or go the 4 mil route. No way I'd want a spacer plate for just a long rod. If I'm using a spacer plate, then it would def be for a +4 crank! Just another place for an air leak otherwise.
« Reply #12 on: July 18, 2014, 11:24:18 AM »
Put a 4mm Hot Rods in it. With the new one I wouldn't worry about it. No need to even have it welded. I run one in my bike and have no issues, when racing I hold it WFO off the rev limiter when launching.
Offline Snowmaker10
« Reply #13 on: July 20, 2014, 01:25:29 AM »
Rupp, where can a guy get a for sure newer +4 from?  Or is it just all the hot rods +4 cranks?  I have a hot rod crank in one of my bike with zero issues so I trust them, just want this to be bulletproof.
Offline Snowmaker10
« Reply #14 on: July 26, 2014, 10:36:56 PM »
Thanks tony!  Here is my latest update to the build.  All new bearings, seals and bearing tabs for the bottom end all for 130$ not 200+ from bdt. Which I just dont understand.  They are all honda.
Also, gonna send the jug and cases to Arlan @led next week for machine work and a new piston.
