Author Topic: Motor years by case ID  (Read 4387 times)
« on: July 20, 2014, 03:22:09 PM »
The 85 to 87 years cases were cast a bit different up front where the front motor mount bolt goes through compared to the 88-89 years cases.The 85-87 has a narrow gap about an inch apart where the case halves come together. The 88-89 year cases have a much bigger gap which is over 3" long as can be be seen below on the green motor. To the left of the green motor there is a 1986 sivler motor.
Offline Sand_Blaster
« Reply #1 on: July 20, 2014, 05:06:23 PM »
Dude thanks for posting this. I have a spare motor which I had no info on & this helps.
87 Trx250r & 99 Banshee
Offline mandom250r
« Reply #2 on: July 20, 2014, 05:27:32 PM »
« Reply #3 on: July 20, 2014, 05:36:11 PM »
Also have engine serial numbers listed in our FAQ section:
http://trx250r.org/threads/1878-Engine-Serial-Numbers-1986-1986-TRX250R
« Reply #4 on: July 20, 2014, 06:05:33 PM »
Thanks guys for listing the number system for the true ID. But I get alot of how do I tell if I have a 85-87 or 88-89. Usually has something to do with the kicker set up on the clutch cover. But it is so obvious by looking on the outide what year your cases are. I have seen them mixxed from every year also. This was just a quick way to anwser a chatbox question [MENTION=392]zarathos[/MENTION]
Offline zarathos
« Reply #5 on: July 22, 2014, 10:18:12 PM »
Thanks for taking the time to make this thread Tony! I had already discovered what I needed to know, turns out I have an '86 engine in my '87 chassis, or should I say I had. I had to sell my R on Saturday for financial reasons. This question came up during the sale.
