Author Topic: ricky stator install  (Read 5100 times)
Offline PORTED R
« on: August 08, 2014, 01:14:27 PM »
So I'm about to install my brand Ricky stator on my bike but I noticed the wire color on the two single connectors are colored different then the ones on the OEM harness
Does anyone know which one connects to what?
Bike is a 86
Thanks
McCoy ProX 350 5mil Duner
« Reply #1 on: August 08, 2014, 02:16:33 PM »
The easiest way to fix this problem is by returning that Ricky stator before you instal it, and buying a used oem. Because that Ricky stator will last maybe 1 season
« Reply #2 on: August 08, 2014, 02:23:03 PM »
Yeah what he said^^^^^^^^^^
You know better AJ
Offline PORTED R
« Reply #3 on: August 08, 2014, 02:23:27 PM »
I always thought Ricky stators worked decent on the Honda ?
If I had a OEM laying around I would use it
My current one is barely keeping up ha
Offline PORTED R
« Reply #4 on: August 08, 2014, 02:26:08 PM »
Quote from: Rupp250;40599
You know better AJ
Ya I know ,its been sitting on my shelf for a year ,figure I use it
Probably won't now
« Reply #5 on: August 08, 2014, 02:32:28 PM »
Heck put it on and if it works, it works. You can always buy an OEM down the road.
P.S. I have a couple and will keep 1 with me when we need to go ride for a spare for you good buddy.:fighting0071:
Offline PORTED R
« Reply #6 on: August 08, 2014, 02:38:06 PM »
:encouragement::ride:
« Reply #7 on: August 08, 2014, 03:21:39 PM »
Quote from: Rupp250;40602
Haha! Good friend to have around!
Offline The_Steve_Man
« Reply #8 on: August 08, 2014, 03:57:56 PM »
I know several guys using high output ricky stators without problems.
A lot of tecate guys run ricky stators because the oem are junk.
Offline muthahucker
« Reply #9 on: August 09, 2014, 01:37:14 PM »
Ive run a high output stator from them for 3 years, no problems at all.  Good customer service as well when I talked to them.  They make a race style wiring harness for the TRX now as well
Offline mandom250r
« Reply #10 on: August 09, 2014, 02:19:51 PM »
I run a 200watt ricky and flywheel that i bought used so i can run my Baja Designs HIDs and work great
