Author Topic: Reinforcement rings  (Read 16883 times)
Reinforcement rings
« on: August 09, 2014, 11:31:43 AM »
Quote from: fourtrax
Hello, I saw in a few of your pics that your trx wheels had some sort of custom reinforcement rings welded in, did you cut those yourself? If so would you be able to cut me a pair?  Thanks for your efforts, Jason
Ac racing used to make a set with stars on them would this be difficult?
I used to use the cnc punch press and were limited to shapes of punches we had in stock. I cut these back in 2001.
With a little programming I can modify the star the resemble the one AC racing made as I can now cut them on the waterjet.
Reinforcement rings
« Reply #1 on: August 09, 2014, 11:47:40 AM »
I'd love these dang things!
Offline fourtrax
Reinforcement rings
« Reply #2 on: August 09, 2014, 12:37:38 PM »
Wow, awesome...so you could cut them thicker with the waterjet?
Reinforcement rings
« Reply #3 on: August 09, 2014, 01:50:03 PM »
Quote from: fourtrax;40653
The 1/8" are more cosmetic than structural. I am only riding the sand and hit an occasional tree root or tree itself. If your doing desert or dirt you will want to go 3//16". The waterjet just has better software for cutting shapes. The drawback is the part becomes sandblasted on the inside and is difficult to polish. The welding of the thin aluminum rims is very critical. You will need someone with a fair amount of experience to weld without warping/ruing the rim. I have a jig that centers the ring on the rim and has 8 spots marked to tack it together. You just can't start on one side and weld all the way around.
Offline fourtrax
Reinforcement rings
« Reply #4 on: August 10, 2014, 12:40:03 PM »
Is it possible to put something on the back side to protect it when cutting on the waterjet? I  use duct tape to protect my surfaces when getting things sandblasted. Just thowin that out there...
Reinforcement rings
« Reply #5 on: August 10, 2014, 12:49:21 PM »
I clamp the sheets in an inch above the cutting grates and use the PVC coated material. But there is no perfect way. There are always those times when you are not lucky. 95% of the parts I cut above the grates do not get sandblasted. The other 5% go in the dumpster unless they get painted.
The stars in the pic you posted are very fragile where the web is unprotected. I can see those getting damaged real soon. You would probably want to go a bit thicker on the web. Makes the polishing difficult also. But they do look cool.
Reinforcement rings
« Reply #6 on: August 10, 2014, 02:45:23 PM »
I programmed this one this morning, not sure if if its the one you want. Made of 3/16" thick with a 3/16" web.
Side view to see thickness
Offline KASEY
Reinforcement rings
« Reply #7 on: August 10, 2014, 03:28:13 PM »
oh yeah just this morning huh?  SHOW OFF!!!!
 THATS DAMMM KOOL
Reinforcement rings
« Reply #8 on: August 10, 2014, 03:59:09 PM »
I approve of this.
Offline KASEY
Reinforcement rings
« Reply #9 on: August 10, 2014, 09:07:47 PM »
OK... I see a need for 6 of these for 7 inch wheels out of 1/8 steel,,,, I will get the outside measurement for them,,, can I get a price?
Offline Bowtie316
Reinforcement rings
« Reply #10 on: August 10, 2014, 10:08:21 PM »
That is so awesome, I wish I could do that!
Reinforcement rings
« Reply #11 on: August 22, 2014, 11:59:47 AM »
Quote from: KASEY;40714
7 3/4" and 8 3/4" in the star pattern are $12 each in 1/8" thick mild steel. With shipping at $12 also.
Offline KASEY
Reinforcement rings
« Reply #12 on: August 22, 2014, 09:59:08 PM »
DO YOU HAVE ANY MATERIAL THINNER THAN 1/8?   if you do I am in for 4 @ 7.75  to start this off
Reinforcement rings
« Reply #13 on: August 23, 2014, 12:34:31 AM »
Quote from: KASEY;41559
The next 2 gauges down are 12 gauge which is .105" then it drops to 14 gauge which is .075"
Offline KASEY
Reinforcement rings
« Reply #14 on: August 23, 2014, 09:29:59 AM »
ok 12 ga. please,,,  6 @ 7.75   and we will go from there,,    thanks  just pm me when ready
