Author Topic: Axle Nut  (Read 5494 times)
Offline zcarlson12
Axle Nut
« on: August 10, 2014, 10:13:43 PM »
I've noticed that after each ride recently my rear brake hub is loose. I don't have an anti-fade, just the regular nut from T&T. Is there something else that's causing this or do these really come loose this often?
Offline Bigred
Axle Nut
« Reply #1 on: August 10, 2014, 10:36:30 PM »
Gotta really reef on it then take electric tape an wrap it tight
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Bigred
Axle Nut
« Reply #2 on: August 10, 2014, 10:37:30 PM »
I also have a stock one if u want it to try
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline zcarlson12
Axle Nut
« Reply #3 on: August 11, 2014, 09:34:27 PM »
Thanks for the offer Bigred. I came up with a couple ideas after talking with my friends at a local machine shop so I'm going to try those and if that doesn't work out I'll just buy an anti-fade. I was curious to see if other people had the same problem often. How do you like that TC ported cylinder?
Offline The_Steve_Man
Axle Nut
« Reply #4 on: August 11, 2014, 09:54:20 PM »
Just tighen up and wrap it with electrical tape. It works.
Offline aztecgwynn
Axle Nut
« Reply #5 on: August 12, 2014, 03:31:05 PM »
Quote from: zcarlson12;40718
Use Honda specs when tightening bolt or nut. I use blue loc tite but not too much, and have never had any problems doing it using Hondas specs.
Axle Nut
« Reply #6 on: August 12, 2014, 03:36:21 PM »
Tighten and racers tape/duct tape etc. This is how it was done back in the day and nearly 30 years later still the way to go for a stock setup.
Offline zcarlson12
Axle Nut
« Reply #7 on: August 13, 2014, 09:59:47 PM »
Got it tightened correctly this time I hope so we will see what happens. I don't see it being a problem again, thanks everyone.
