Author Topic: Burning through spark plugs  (Read 4125 times)
Offline markdrummer
« on: July 13, 2013, 12:29:31 AM »
So I'm going through plugs about every two hours of riding. bike wont idle, running 32-1 93 octane ethanol free... wth is going on
Offline traxman
« Reply #1 on: July 13, 2013, 12:39:58 AM »
Are they fouling out??? A little more info would be useful. One thing if it started doing this out of the blue is the choke could be broke and not shutting off complete. Please be a little more specific..
Offline motofool250r
« Reply #2 on: July 13, 2013, 08:32:20 AM »
pics of the plugs and jetting settings, pilot jet, main jet, needle number, and clip location would be helpful
Hybrid Stable
443cc LSR/Roll/Stellar Duner
363cc Backup Duner
In progress JP no-link Duner
Next bike now loading.....
Offline trx250scar
« Reply #3 on: July 13, 2013, 01:59:44 PM »
i had a leaking head gasket and the coolant seemed to burn out the plug. bike would run fine until all at once it would shut down, but only would shut down when the rpm got low. never just cut out when you were in the throttle. it was leaking slightly enough that the radiator would get low, but it was not often enough to suspect a bad leak. thought it was just pissing outta the over flow because its hot in florida.
« Reply #4 on: July 13, 2013, 02:06:45 PM »
try adjusting the air screw out and see if it idles better
