Author Topic: Is this too good to be true?  (Read 4544 times)
Offline nathan89
« on: August 19, 2014, 02:54:19 AM »
Anybody running one of those eBay radiators for about $70? They look decent but that sure is a cheap price. I wonder how they work?
Here's a link:   http://www.ebay.com/itm/Aluminum-Radiator-Honda-TRX250-TRX250R-86-87-1986-1987-TRX-250R-TRX-250-/261248954430?pt=Motorcycles_Parts_Accessories&hash=item3cd3a6b03e&vxp=mtr
« Reply #1 on: August 19, 2014, 04:26:12 AM »
I have found auctions that include color hoses for $105 shipped
« Reply #2 on: August 19, 2014, 07:17:42 AM »
Im running one on my XC bike, The lower pegs didnt fit very well, the radiator is so wide that it hit the frame before dropping in the lower holes, so i made adapter brackets and it works great, the construction seems really good.
« Reply #3 on: August 19, 2014, 07:20:35 AM »
I have one and it seems just fine. The lower spigot gives some people trouble on 88/89 frames. I also have a thicker one now. http://www.ebay.com/itm/ASI-COOLING-NEW-heavy-duty-52MM-aluminum-radiator-HONDA-TRX250-TRX250R-86-87-/281409700333?pt=Motors_ATV_Parts_Accessories&hash=item41855341ed&vxp=mtr It's the same as one that a performance shop sells for $200.
« Last Edit: August 19, 2014, 09:15:56 AM by rk88r »
Offline TRXforever
« Reply #4 on: August 19, 2014, 08:06:09 AM »
I run one of those ebay radiators with no problems at all! Had to re-align the lower spigot a little, but works great!
« Reply #5 on: August 19, 2014, 09:21:23 AM »
Quote from: Burns363R;41199
What temps are you at normally with that radiator Burns? During XC racing that is.
I'm probably going to pick one up just to be safe
« Reply #6 on: August 19, 2014, 09:23:42 AM »
I havent rode a race with this radiator yet.  Before with a stock radiator i was seeing way to hot of temps.  I have put a BB pipe on and this larger radiator since and have done some testing.  Temps are running int he 180's, i attribute it to both the larger stinger and radiator though.
My 363 was simply making to much heat for a stock radiator and a smaller pipe stinger, just couldnt get rid of it in time.
« Reply #7 on: August 19, 2014, 09:42:46 AM »
This is a decent radiator, but in my experience, it didn't cool any better at all than a stock radiator. I saw the exact same temperature with the stock radiator and this one. However, if you have a beat up stock radiator and need a replacement, it's definitely worth the money.
Offline nathan89
« Reply #8 on: August 19, 2014, 06:38:55 PM »
Quote from: rablack21;41215
That is what I'm looking for... just a new, oem replacement. My stock radiator is in good shape, but it has a few coats of paint on it. I'm sure the paint is hurting the efficiency of the aluminum at removing heat. I can't think of any safe way to remove the paint from the radiator. . . . .
