Author Topic: 86 trx250r  (Read 5887 times)
Offline Bigred
86 trx250r
« on: August 19, 2014, 10:38:50 PM »
Frame up 10 hrs on it.  Only reason for sale is my wife wants to ride with me and this is the only "money" I have to deal with would be intrested in a 05+ forman rubicon price is 4,000 I'm in erie  pa  can text pics not sure how to post um any more with Photobucket being changed.
Oem plastics no cracks some pier webbing still look good*
Oem seat and cover
Oem tool box and tools
Oem88 headlight and hood
Oem swingarm steering stem and a arms painted gloss black
oem uncut wire harness*
oem kill switch headlight on off switch cluster
Oem tail light*
oem coolant overflow bottle
Oem 86 frame straight never been welded that I can see or know of
Oem radiator
oem airbox snorkel and intake tube
rebuilt for 220 lbs oem rear shock
Oem calipers front and rear along with front break lever and resivor
Oem brake lines and discuss rotors
Oem spindles and front hubs
Oem 88 cylinder mid top port by tc racing
Oem 86 bottom end. I bought this had 3 races on it since rebuild but lost papers so take it as you'd like I paid a nice penny for it
Aftermarket. ..
38 mm as carb
Boysen rad valve
Reed spacer for fitment
Fmf exhaust. it's painted
In line temp gauge and cooler with red hoses
Prm front and rear bumpers
Full skids belly arms and swingarm
Motor painted on base clear black bottomend silver jug
Steering stabilizer
Dwt bead locks trex tires on front gncc holeshot on rear
400ex 0-+4 durable axle and lock nut These parts could used clean only thing didn't get to
new a arm . swing arm . Steering and rear axle bearings and bushings all pivot works
Ims gas tank
works triple rate front shocks 200 lbs
10-12 hrs on build
Have a dyno graph
crank it up gears retro graphics
Cool head
Hinson clutch basket
Pump fuel
Engine ice coolant
fat bars
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Trusty2stroke
86 trx250r
« Reply #1 on: August 19, 2014, 11:37:24 PM »
Why not just ride two people on the R lol??
Offline Bigred
86 trx250r
« Reply #2 on: August 19, 2014, 11:39:39 PM »
We're bigger people lol we don't fit
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
86 trx250r
« Reply #3 on: August 19, 2014, 11:40:28 PM »
Not to mention the front end don't stay on the ground even while putting ha ha ha
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
86 trx250r
« Reply #4 on: August 19, 2014, 11:41:13 PM »
Number for pics is 814-440-8767
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
86 trx250r
« Reply #5 on: August 27, 2014, 09:07:07 AM »
Might part out if enough intrest will post prices if there is a big intrest
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
