Author Topic: ESR 310 cylinder install ?  (Read 2132 times)
Offline jfwyatt1
« on: August 22, 2014, 07:45:34 PM »
finally have got around to workin on it and have a couple of questions 1st im doing the leakdown test now and the PV kept giving me a fit i ended up putting teflon tape on the threads of the adjustment screw and then tightening the nut back down then pulled out the jet that is screwed into the side and sealing it off with a bolt. i pumped up the cylinder to 8LBS and left it for about a half hour and it had only lost a bit less than a pound and seems to be staying at just over 7lbs for the last 15min or so. is it normal for air to leak past the shaft in the PV? also what psi should i expect from the pump gas dome? that will be the next test in the morn. my plan is since the only local place that sells 110 is getting over $10 a gallon for it to run non ethenol 93 my uncles station carries it and i know its from a good source. would it benefit me even with the pump gas dome to maybe mix it 1 gal. 110 to 4 non eth 93? is there anything else i should check before i start the breakin? thanks guys
