Author Topic: Boyesen Rad Valve  (Read 8451 times)
Offline Allison#51
Boyesen Rad Valve
« on: August 23, 2014, 01:36:43 PM »
Somehow I ended up buying a cr rad valve so I'm looking for a trx one now. Anyone have one you can sell?
Offline mennis1971
Boyesen Rad Valve
« Reply #1 on: August 23, 2014, 02:02:16 PM »
I'd maybe trade a trx for a cr one. I have 2 you can pick from. Are you 100% sure it's a cr one and what kind of shape is it in?
Offline supernutt
Boyesen Rad Valve
« Reply #2 on: August 23, 2014, 04:24:12 PM »
I would be interested in a even trade also as long as yours is stamped 02B. Mine is 04A.
Boyesen Rad Valve
« Reply #3 on: August 23, 2014, 04:26:55 PM »
Quote from: mennis1971;41611
Is there a number on your Rad Valves
Most of  the early CR250 Rad Valves have a 02B and the ATC250R and TRX 250R had a 04A stamped on them.
Looks like supernut was typing at the same time I was
Boyesen Rad Valve
« Reply #4 on: August 23, 2014, 05:11:54 PM »
You want the 02B. Works better in most applications... Other than fit and alignment. Use a 3/4" reed spacer.
Best regards
-Jason
Offline supernutt
Boyesen Rad Valve
« Reply #5 on: August 23, 2014, 05:14:08 PM »
That is what I have heard and would love to try one out!
Offline Allison#51
Boyesen Rad Valve
« Reply #6 on: August 23, 2014, 07:32:19 PM »
I'll pull it back off tonight.. Not sure I wanna get rid of it right away though cause I wanna compare them.
Offline supernutt
Boyesen Rad Valve
« Reply #7 on: August 23, 2014, 07:32:48 PM »
Good idea. I would be interested with the results
Offline Allison#51
Boyesen Rad Valve
« Reply #8 on: August 23, 2014, 07:44:55 PM »
Okay I'll post up some good pictures and dimensions when I find one
Offline Allison#51
Boyesen Rad Valve
« Reply #9 on: August 25, 2014, 10:22:51 PM »
Mine only has 02 stamped in the side. I'm still looking for a trx one if anyone has one. The condition of the reed petals and boot doesn't really matter since I have new one's. Just need a good reed block
Boyesen Rad Valve
« Reply #10 on: August 25, 2014, 10:43:25 PM »
I have one that's stamped 04 if you wanna try it. I have new pedals and a good boot I could send along...
Boyesen Rad Valve
« Reply #11 on: August 26, 2014, 09:15:40 AM »
Offline Anthony0327
Boyesen Rad Valve
« Reply #12 on: August 26, 2014, 11:25:20 PM »
I have a 250r rad valve brand new in box. Pm me if interested
Boyesen Rad Valve
« Reply #13 on: August 27, 2014, 01:06:43 AM »
Quote from: Allison#51;41747
I think the CR rad valve reed petals are a little shorter than the TRX petals. I'd have to look through my spare parts to verify that but I remember finding a set of carbon petals that were slightly taller than the ones on my CR cage.
Offline 250r fanatic
boysen rad spacer
« Reply #14 on: September 22, 2014, 06:06:53 AM »
I have one for sale if anyone is looking
