Author Topic: cr ignition ?  (Read 3123 times)
cr ignition ?
« on: August 28, 2014, 08:33:38 PM »
I have a 2000 cr setup to put in my r. What are you guys doing with the grommet for were the wire loom goes through the case?
Offline Grande huevos
cr ignition ?
« Reply #1 on: August 28, 2014, 09:17:37 PM »
You have to trim it down to size... I held it next the one off my trx ignition and marked it with an ink pen then used a bench grinder taking it nice slow until I had a nice tight fit! Then used a dremel with a cutting wheel to cut the groove into the front side. Be patient and take your time it's very crucial that you don't hit the wire and that you get it to fit as tight as possible to keep water and debri out......it's really not all that hard to do once you get started
cr ignition ?
« Reply #2 on: August 28, 2014, 09:25:41 PM »
cool thanks. I figured that was what people were kind of doing. The only problem is my harness has already went to go save another r. So I guess I'll just eyeball it.
cr ignition ?
« Reply #3 on: August 28, 2014, 10:35:35 PM »
well that wasn't to hard. It fired first kick. I have it pieced together. So I could fire it. Will do my final assembly of it once I get coil mount from puma
