Author Topic: Spacer Plate - Questions ( Dowel pins )  (Read 3160 times)
Offline CeaserTheThird
« on: September 02, 2014, 10:26:04 PM »
Question - do I need to purchase longer dowel pins to compensate for spacer plate ?
I did measure and they do extended out. But not sure if this will be a problem.
Order New " OEM stock size 12x20 " - dowel pins extend out 5.50 MM ( will this be safe to insure the cylinder stays in place ? )
Pictures
I did order the correct longer studs off the CR :)
« Last Edit: September 03, 2014, 01:29:39 PM by CeaserTheThird »
Offline Bowtie316
« Reply #1 on: September 03, 2014, 08:11:45 AM »
I used stock alignement barrels with the .190 spacer plate with no issues.
« Reply #2 on: September 03, 2014, 12:29:21 PM »
Those will work just fine.
« Reply #3 on: September 03, 2014, 01:29:01 PM »
Great awesome, thank you.
