Author Topic: lighting issues  (Read 7943 times)
Offline PORTED R
lighting issues
« on: September 03, 2014, 06:01:45 AM »
So recently my trx frame took a dump(cracks,broken motor mounts )
So Im currently riding my atc250r
As I was getting the bike all done and fired up ,the headlight and taillight don't come on
I've cleaned the switch ,checked bulbs all good
Bike has OEM OG wire harness ,cdi ,stator but new OEM coil
And none of them are molested
The only time they worked is after a few seconds after turning them on they flickered once then the bike died ha
McCoy ProX 350 5mil Duner
Offline Bowtie316
lighting issues
« Reply #1 on: September 03, 2014, 08:15:20 AM »
I would start by checking the lighting coil in the stator per the manual.  You can do it by unplugging the connector up by the CDI on a trx, not sure about the atc.
Offline PORTED R
lighting issues
« Reply #2 on: September 03, 2014, 11:56:58 AM »
I belive it is the stator for some odd reason ...ha
I'll check that out and swap the A/C regulator out just in case
I'm getting a huge list going on stuff I'm doing to my bikes when the weather cools down a bit
Offline PORTED R
lighting issues
« Reply #3 on: September 03, 2014, 11:57:35 AM »
Thanks
