Workshop
Suspension and Chassis
honda-yamaha wheel drilling
Topic: honda-yamaha wheel drilling (Read 5230 times)
trx250scar
September 06, 2014, 09:52:34 AM »
Does anyone have a plate to drill Honda 4x110(rears) to Yamaha blaster 4x100 (rears). It's kind of a long shot for the blaster pattern, so does anyone know if a blaster stock axle accept stock banshee hubs(4x115). I got a good deal on some almost new 18" paddles and wheels that will go great on my wife's blaster.
Last Edit: September 06, 2014, 10:07:48 AM by trx250scar
jcs003
Total likes: 44
September 06, 2014, 10:36:41 AM »
i remember back on atvriders a guy had drilling templates. another option is to lay them out and center punch then drill.you could also have a machinist drill it for you.
supernutt
Total likes: 2
August 09, 2015, 02:18:48 PM »
I am having the same issue here. I was given a set of 4x100 rear wheels with nice sand skate 2's on them. I am wondering if anyone knows of another rear hub that fits the 250r spline but is 4x100 bolt pattern? New wheels are $100 for the cheapest set I can find and I am sure I can buy used rear wheel hubs much cheaper.....
97 Laeger XC narrow CR500 link +4 t-pin
Pumashine
Supporting Member
Total likes: 27
August 09, 2015, 02:40:20 PM »
Dave Moore was selling drilling templates on Facebook. I cut 1/2" plate with both bolt patterns. You bolt the template on and use the plate as a drill guide to put in 4 new holes.
I think Blaster ans Banshee are the same so there are proly alot of them out there.
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
trx250scar
August 09, 2015, 06:11:38 PM »
Blaster and banshe rears are not the same but the fronts are.
The norm
Total likes: 327
August 11, 2015, 11:07:41 PM »
The splines on the blaster axle are the same as the banshee, yfz, and raptor. I have a template that I made to adapt the blaster wheels to Honda pattern. The problem is that the valve stem is kind of in the way of one hole.
The norm
Total likes: 327
August 11, 2015, 11:10:25 PM »
You can use the rear hubs of a yfz, raptor, or banshee
JesseA420
August 12, 2015, 07:04:36 AM »
i have a set of raptor hubs u can have, the splines are a little worn but if you swartzanegger the axle nut it will work fine.
Workshop
