Author Topic: Sparks pipe and silencer  (Read 5655 times)
Offline ccaiazza
« on: September 07, 2014, 08:10:55 PM »
Just installed a sparks pipe and silencer today. The pipe fits ok, when you rev it up the pipe wants to separate , the springs aren't stiff enough but i think some sealant will fix that. The issue is the silencer it fits like crap, hits the frame when mounted to the rear mount and dosent even come close to the lower mount. If anyone has a pic of there sparks set up i would like to see how yours is done. And any suggestions are welcome
« Reply #1 on: September 08, 2014, 09:18:17 AM »
Yes, you will need to use some sealant. The springs are not enough. On my sparks setup, I mounted the silencer using one of the rear exhaust hangers. You won't be able to use the lower mount, atleast I couldn't on mine. I also had to make a bracket to mount mine to an exhaust hanger on the front motor mount. I will try to post some pics first chance I get.
Offline ccaiazza
« Reply #2 on: September 08, 2014, 10:20:55 AM »
Yes, I also made the motor mount bracket, but the silencer is a pain in the ass. I had an Lrd mounted before and it fit perfect. I am a little anal about fit and look. I don't want to have a cobbled up look! Waiting patently for pics lol
« Reply #3 on: September 08, 2014, 10:33:42 AM »
I know this is not a Sparks silencer, but I am using the same exhaust hanger for the rear most mounting location. Like I mentioned, you can use the lower mount with this setup. But you should be able to set up your silencer with this same rear most exhaust hanger. Hope this helps.
Offline Victork
« Reply #4 on: November 19, 2014, 03:13:41 AM »
My silencer fits like a glove
Offline ccaiazza
« Reply #5 on: November 20, 2014, 07:41:45 AM »
Finally got it to fit the way i wanted . Thank for all the input. Vic i would tighten that chain before your buying cases.
« Reply #6 on: November 20, 2014, 08:28:11 AM »
Lets see some pics of this Sparks pipe
Offline Victork
« Reply #7 on: November 21, 2014, 01:30:59 AM »
Quote from: ccaiazza;46263
i took the bike apart to gusset and powder so no worries there lol
