Author Topic: Shock Rezzi holders  (Read 4872 times)
Offline marine
Shock Rezzi holders
« on: September 20, 2014, 12:02:23 PM »
Hi Huys. Does any one know if JRD Racing is still around? I had a set of there Rezzi holders that worked well.If some one has a set that they would like to sell please let me know or if anyone knows of a company that makes a similar design that would be very helpful. Thank you. USMC
Offline marine
Shock Rezzi holders
« Reply #1 on: September 20, 2014, 12:32:30 PM »
Thank you very much for your help. I will contact him. USMC
Shock Rezzi holders
« Reply #2 on: September 20, 2014, 12:41:19 PM »
http://trx250r.org/threads/1987-Trx250r-Resi-clamps   I build them for your size reservoirs. Every manufacturer has their 0wn sizes of resi's as well as different sizes for larger and smaller applications. Just need to know which frame tube you are going to mount to and your resi diameter.
Offline marine
Shock Rezzi holders
« Reply #3 on: September 20, 2014, 02:10:00 PM »
Hi Pumashine. Thank you for replying. They would be going on a Laegers frame up front the rear is currently mounted on the upper part of the frame near the fuel tank. The shocks are Custom Axis. I would like them polished if possible. I would also be interested in a polished Stator cover as well. Please let me know how to place the order and the cost. Your help is greatly appreciated. USMC
Shock Rezzi holders
« Reply #4 on: September 20, 2014, 02:14:59 PM »
Quote from: marine;43088They would be going on a Laegers frame up front the rear is currently mounted on the upper part of the frame near the fuel tank. The shocks are Custom Axis.  USMC[/QUOTE
The ones I make for the after-market frames mount to 1" OD round tubing. You need to physically measure the diameter of the resi itself to give me a number I can work with.
Offline 4Wheelmx
Shock Rezzi holders
« Reply #5 on: September 20, 2014, 02:46:38 PM »
I have some JRD rezzi clamps I would sell. They are for a Laegers and custom Axis shocks.
Offline marine
Shock Rezzi holders
« Reply #6 on: September 20, 2014, 02:51:52 PM »
I would be interested. Do you have a number I can call you at? Thank you
Shock Rezzi holders
« Reply #7 on: September 20, 2014, 03:00:08 PM »
Those are sweet. Great score!!!
Offline 4Wheelmx
Shock Rezzi holders
« Reply #8 on: September 20, 2014, 03:01:34 PM »
P.M. sent.
Offline marine
Shock Rezzi holders
« Reply #9 on: September 20, 2014, 03:25:24 PM »
P.M Sent
