Author Topic: Need a little help  (Read 3727 times)
Offline Jar350r
Need a little help
« on: July 13, 2013, 08:11:26 PM »
Ok need help start point for jetting ,got a lrd 265 pv ported for mx it s got fmf exhaust boysson reeds 38 a/s carb I am at 870m 2850 feet and it running 50/50 race and preamium and a Esr air box elemnator kit and a roost boost mix gas at 32:1
« Last Edit: July 14, 2013, 11:25:38 PM by Jar350r »
Need a little help
« Reply #1 on: July 14, 2013, 10:22:20 PM »
Its only been 2hrs and its Sunday evening,Im sure everone is with their families.  Someone Im sure will be along to help. Whats your compression and or dome size cause that will have an effect as well. What is the jetting now,have you run it yet? If so how does it run in all ranges of throttle,is there an issue with how it runs,ie are we trying tonsolve a ridability issue or just a new setup? Whats the temp where your at?
« Last Edit: July 14, 2013, 10:37:44 PM by 05450r »
Offline Polonda
Need a little help
« Reply #2 on: July 14, 2013, 10:38:12 PM »
Start fat. 180 or larger main. 52 pilot. Set air screw to achieve highest idle. If more than 2.5 turns out put a smaller pilot. Less than 1.5 go larger on the pilot.
Need a little help
« Reply #3 on: July 15, 2013, 10:28:30 AM »
Quote from: 05450r;3753
If you need answers right away try using the shout box. There is also a stickie in the tech section for jetting base guild lines.
