Author Topic: 1985 honda atc low hour engine for sale  (Read 1846 times)
Offline aztecgwynn
« on: September 28, 2014, 12:25:02 PM »
I have been holding on to this engine for some time now! But I bought this years ago and as you can tell from pics it ha not much use on it, it has not much wear on stator cover so you can see that it is low hours engine. I have had this engine wrapped in plastic to protect from elements even though it has been sitting in a closet for some time now. Cylinder is still standard and cross hatch can still be seen, cases are immaculate, and still has awesome compression and lower oil bolt not cracked or stripped. I recently took head of to measure bore and to see if piston has any play and piston has no play but it did have the original honda top end cylinder gasket. So i will give option to put a 1985 atc 250r metal gasket or a cr 250r metal gasket. I will be asking $900 for engine shipped. Engine still has original cast piston in it, if additional questions need to be answer feel free to PM me and I will get back to you as prompt as possible thanks.
