Site Sponsors
Pumashine 250R Products
87-89 gusset welding pics
Topic: 87-89 gusset welding pics (Read 14827 times)
Pumashine
Supporting Member
Total likes: 27
October 11, 2014, 12:45:48 PM »
DOWNLOAD THE GUSSET WELDING THREAD HERE
https://www.forums.trx250r.org/index.php?action=dlattach;topic=4525.0;attach=2426
The 1986 front motor motor mount sub structure is a stout cast iron piece that may start fracturing from the frame. Fixing consists of just welding up the cracks. On the 87-89 sub structure the thin sheet metal design tends to start cracking at the inner corners just under the front motor mounts. This area is marked by a red line in the pic.
The thick small triangle shape pieces supplied in the 87-89 gusset kit are tacked in place just inside the frame up against the sub structure. This will leave room to leave a nice weld. The sub engine mount gussets reinforce the sub mount to keep it in place as it is subject to twisting and vibration. The twisting of e power full motors easily starts a crack in the sub mount. Weld the crack up and reinforce the sub mount with these small gussets.
https://oi345.photobucket.com/albums/p361/Tonygusset/DSC01364_zpsxeyfwwun.jpg
https://oi345.photobucket.com/albums/p361/Tonygusset/DSC01365_zpszphlznki.jpg
Last Edit: January 05, 2020, 04:35:22 PM by Pumashine
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
havinnoj
Administrator
Total likes: 185
Re: 87-89 gusset welding pics
October 08, 2019, 02:13:51 PM »
PDF of Gusset Install attached
(2 people liked this)
Site Sponsors
