Author Topic: smoothing out casting flaws  (Read 5272 times)
Offline dirtyd
« on: October 25, 2014, 03:29:30 PM »
This is not for a R but the principles I would figure to be the same. I got this Tecate-4 engine I'm putting back together. The cylinder in unported and it has some excess material from the casting. I'm not going to port it. I'm just wondering if I could screw up the performance by knocking down these sharp edges and high spots.
87 Tecate4- new project
Offline PORTED R
« Reply #1 on: October 25, 2014, 03:59:47 PM »
In general
I believe there's nothing wrong with cleaning up ports
Ur best bet for performance improvment
Is to clean up the exhaust ,lower and reed ports
Don't dig too deep ,just enough to clean it up
McCoy ProX 350 5mil Duner
« Reply #2 on: October 25, 2014, 04:57:06 PM »
Removing excess material and rounding sharp or flat edges that protrude into the air flow cannot harm performance. I believe it is called clean and match. The aluminum that surrounds the sleeve can be removed if it blocks the sleeves ports.
« Reply #3 on: October 25, 2014, 05:42:53 PM »
what tools do you have ? no point in doing a half ass job
Offline DnB_Racing
« Reply #4 on: October 25, 2014, 05:58:01 PM »
one thing to consider, as im not sure of your plans about resale...once you clean it up its no longer a untouched cylinder,  you wont gain much by cleaning, but will depreciate it in the process, just something to consider,
« Reply #5 on: October 25, 2014, 09:08:55 PM »
Quote from: DnB_Racing;45015
Funny you should say that. All trx250r cylinders untouched were gone through to remove casting flaws and anything unexpected left behind from the cast. You will observe slight clean and match work with any 250r cylinder. The work is very course (120 grit) but none the less was done. I doubt the tecate cylinders were any different.
« Reply #6 on: October 26, 2014, 12:52:07 AM »
i thought it was his own bike but ya if your going to sell then leave it be and just slap it back together. either way if you smooth it or not, dont expect a huge difference . doesnt look like the average dremel will get in there very good anyways. probly better off not doing anything
« Reply #7 on: October 26, 2014, 03:18:00 AM »
What you need is one of these:
I tried using a dremel with the snake attachment first but the micro die grinder made it a lot easier. It's very compact, has an 1/8" collet & a variable speed dial on the back.
Offline dirtyd
« Reply #8 on: October 26, 2014, 10:20:00 AM »
I may just leave it, I dont know. I'm not looking to gain power, if I was I would just send it out and have it ported. I just figured while its apart why not smooth it out. I was going to part this bike but some of the extra parts I was selling were moving very slow. So I decided to just make it another winter project and put it back together. I.m not going to dump a bunch of money into this, just fix or get whats needed.
