Author Topic: UPP Case Saver  (Read 8591 times)
UPP Case Saver
« on: November 04, 2014, 08:38:25 AM »
For anybody who was considering buying the UPP case saver, here's what it looks like mounted on the R. If you're looking for a pretty aluminum case saver, this isn't it. But if you want to get the best protection for your hard to find and expensive case halves, this is it.
With OEM cases and stator covers this required no trimming. People with ESR cases and/or aftermarket stator covers might have to bust out the dremel to shave off some material. A no-brainer if you ask me
« Last Edit: March 26, 2020, 01:43:28 PM by Tbone07 »
UPP Case Saver
« Reply #1 on: November 04, 2014, 08:50:32 AM »
now that is some protection!
UPP Case Saver
« Reply #2 on: November 04, 2014, 10:04:44 AM »
What are these made out of? Is it delrin?
UPP Case Saver
« Reply #3 on: November 04, 2014, 10:08:23 AM »
It made out of one of the polys, polyurethane I believe. Delrin is not impact friendly. Delrin would bust on impact.
UPP Case Saver
« Reply #4 on: November 04, 2014, 10:17:35 AM »
Yeah, it's polyurethane. Here is a write up about polyurethane from UPP and why they chose to use it:
WHY POLYURETHANE?
Because it is a unique engineering material that gives you the power to design in properties impossible to capture with other materials. Plus the power to improve cost performance and find novel solutions to thousands of difficult engineering problems. Overall, products made with polyurethane are stronger, tougher, and more durable than products made with conventional elastomers and plastic.
HARDER THAN BONE OR SOFTER THAN A RUBBER BAND
Polyurethane elastomers can be formulated to create products with a hardness range from 10 Shore A which is softer than a gum eraser, to over 90 Shore D which is harder than a golf ball. As you can see in the comparison chart below, polyurethane has a hardness range far wider than conventional rubbers.
RESISTANT TO ABRASION
Where severe wear is a problem, polyurethane often outperforms rubber, plastic, and metals. In many applications, this abrasion resistance allows users to fabricate polyurethane products with less material than other elastomers would require. Other benefits include lighter weight, longer life, reduced maintenance and lower replacement costs. Since abrasion resistance is a complex property that can very with a number of factors, it is best to rely on our experience in selecting compounds for a given application.
MORE LOAD BEARING CAPACITY AT A GIVEN HARDNESS
Compared to other elastomers of equal hardness, polyurethanes have greater load bearing capacity in both compression and shear. This is an important advantage in many designsú such as stripper springs and press on solid tires. In other cases, this greater load-bearing capacity is what makes some designs possible at all.
HIGHLY RESISTANT TO IMPACT
While conventional plastic materials tend to become brittle as they become harder, polyurethanes remain elastic and resist fracture even in very hard formulations. This great toughness makes polyurethanes ideal for parts that have to stand up to high impact or repeated impingement.
WIDE RESILIENCE RANGE
Unlike rubbers, polyurethanes don't have to be made soft to make them resilient. Hard polyurethanes can be as resilient as much softer materials. For shock absorbing applications, polyurethanes can be formulated with rebound values as low as 10% to 25%. For quicker recovery, or where high-frequency vibrations are a factor, they can be formulated with rebound values up to 40% to 70%.
SUITABLE FOR HIGH-FLEX APPLICATIONS
Under repeated flexing, polyurethanes resist cracking as well as most other elastomers. However, since cracking in any elastomers can be reduced by making the part thinner, polyurethanes offer an important advantage: they can be used in very thin sections because of their great strength and toughness.
FLEXIBLE AT LOW TEMPERATURES
Depending on the formulations, polyurethanes remain quite flexible even in arctic-like temperatures. In addition, polyurethanes have proven remarkably resistant to thermal shock, and withstand sudden and drastic temperature drops without cracking.
STABLE UP TO 200°C (390°F)
In special formulations, polyurethanes can withstand continuous use at 200°C (390°F) or higher. In standard formulations, polyurethanes are suitable for continuous use up to about 90°C (194°F), although they can withstand temperatures as high as 200°C for short periods in certain applications. For advice on high-temperature applications, ask UPP.
WON'T SWELL OR DETERIORATE IN WATER
Polyurethanes remain stable even when immersed in water as warm as 50°C (122°F) for very long periods. (They are not recommended for continuous use in water hotter than about 70°C (158°F).) They absorb practically no water -barely 0.3% to 1 % by weight and show negligible swell in volume even after prolonged immersion. In fact, polyurethanes are used successfully in water-lubricated bearings, where a slight increase in volume would cause seizing.
WIDE RESISTANCE. TO OIL, GREASE, AND CHEMICALS
While many rubbers and plastics show excellent resistance to certain solvents, oils, and chemicals, polyurethanes will resist a much wider range of substances. Polyurethanes are therefore more suitable for products or parts that could come in contact with a number of different substances. As with any material, we recommend that polyurethane be tested for the specific resistance in actual use, or at least on a test that simulates actual use as closely as possible.
HIGH AND LOW FRICTION FORMULATION
Polyurethanes resemble most plastics and other elastomers in that friction against non-úlubricated surfaces generally decreases with harder formulations. Polyurethanes can be formulated with very low coefficients of friction for products like bushings, bearings and wear strips. The wear of shafts and mating surfaces is minimal with polyurethane, and usually much less than with conventional plastics. Additives can be used to further reduce friction. Softer formulations are used where more friction and traction are required, as in solid industrial tires, feed rollers, and drive rollers. RADIATION RESISTANCE Of all elastomers, polyurethanes are considered to have the best resistance to gamma ray radiation. After exposure, they retain virtually all of their original flexibility and toughness.
ELECTRICAL PROPERTIES
Most polyurethanes are excellent insulators. They are used extensively in potting and encapsulating applications, and other areas where electrical isolation is important.
BONDS TO WOOD, METALS, AND MOST PLASTICS
During the molding process, and under controlled conditions, polyurethanes can be bonded to a wide variety of materials. Bond strengths are often stronger than the polyurethane itself, and are usually several times stronger than a similar rubber-to-substrate bond. With special techniques, cured polyurethanes can be bonded to many materials.
LOW MOLD AND TOOL COSTS
The tools and molds used for creating polyurethane products can often be produced inexpensively. Polyurethane itself is frequently used on short runs and for manufacturing special items on short notice. A further advantage of low-pressure liquid casting process is the ability to produce large parts in limited quantities economically.
YES, POLYURETHANES DO HAVE THEIR LIMITATIONS
Like other engineering materials, polyurethanes cannot do everything. The very characteristic that makes them ideal for some applications may make them less suitable for others. And if selected, formulated, or applied improperly they may not perform as expected. To obtain optimum performance from polyurethanes UPP recommends the following:
    Provide us with specific, precise dimensions in your drawings, and let us work with you to optimize design to take best advantage of the polyurethane properties.
    Give UPP as much information as possible on how the part will be used, what you expect it to do, and under what conditions. (Such as flex, tension, temperature, compression, chemical contact, etc.).
VERSATILE, COST-EFFECTIVE, DEPENDABLE
Polyurethane elastomers are unique design and construction materials that combine many of the advantages of rigid plastics, metals, and ceramics with the flexibility and resilience of rubber. Chemically, they are polymers containing urethane groups (-NH-CQ-Q-), created by reacting isocyanates with polyols and chain extenders. By varying the nature of these three components, UPP can create literally thousands of different combinations of properties. Because of this versatility, polyurethanes can be custom-tailored to suit a wide variety of applications. The nature of the casting process can result in lower costs compared to other materials. Low-pressure, liquid casting means low cost tooling economical low-volume production, and great design flexibility. Furthermore, thanks to superior performance characteristics, polyurethane products are also more cost effective.
This is from their website. http://www.uppracing.com/index.php?cid=109
UPP Case Saver
« Reply #5 on: November 04, 2014, 10:18:44 AM »
Makes sense. I use polyurethane bushings in a couple of my cars. Thanks rablack21....... I'll be getting two of these case savers for sure.
UPP Case Saver
« Reply #6 on: November 04, 2014, 10:22:57 AM »
Quote from: broken1;45446
Are you sure you don't want pro-flowed foozun aluminum ones? :with_stupid::carlos:
Offline oldschoolr
UPP Case Saver
« Reply #7 on: November 04, 2014, 10:28:28 AM »
Yeah what he said ^^
UPP Case Saver
« Reply #8 on: November 04, 2014, 10:42:03 AM »
Quote from: Tbone07;45447
I'm sure the brilliant minds in building 3 spent many hours on R&D developing that fancy foozun case saver & they obviously pro-flowed it since it looks like it's only about 1/16" thick in a critical area thus reducing wind drag from the chain going round & round, much like the wheels on the bus.
UPP Case Saver
« Reply #9 on: November 04, 2014, 10:48:57 AM »
Quote from: broken1;45450
If you don't use the UPP case saver the only thing that will get pro-flowed is your left case halve, and your wallet when you have to fix/replace it
UPP Case Saver
« Reply #10 on: November 04, 2014, 01:38:54 PM »
Thanks for posting the pic. I will take another look at cutting these. I think $20 each would be more desirable. And 15 tooth for sure!!!
UPP Case Saver
« Reply #11 on: November 04, 2014, 01:43:22 PM »
Offline Victork
UPP Case Saver
« Reply #12 on: November 04, 2014, 02:54:17 PM »
Might not look as pretty as a alum saver but it looks more badass imo my bottom saver mount was repaired looks like ill have to break the drummel out and pro flow it
UPP Case Saver
« Reply #13 on: November 04, 2014, 03:01:41 PM »
Mines rookie flowed...
UPP Case Saver
« Reply #14 on: November 05, 2014, 09:25:40 AM »
Quote from: Pumashine;45455
But would you be able to make them mold around the clutch actuator area and all the intricate crevasses?
The tiny 1 inch of surface area in contact with the stator cover part of the case (and the bolt mounts) that would bear the force of a chain derailment/jam isn't nearly enough. This spreads it across the entire area
I neglected to take a pic of the backside of the UPP, hold please....
