Author Topic: rickey stator flywheel  (Read 13555 times)
Offline brook310r
« on: November 09, 2014, 06:15:42 AM »
is anyone using the 200 gram lighter flywheel how dose it work good or bad
« Reply #1 on: November 09, 2014, 01:12:22 PM »
Personally, I wouldn't go with a lighter flywheel. Most people say stay away from the Ricky Stator brand of electrical components.
Stick to OEM 250R or go to the CR250 ignitions
Offline tlr7272
« Reply #2 on: November 09, 2014, 01:46:28 PM »
im trying to figure the right electrical set up for my quad????im trying to build the best reasonable budget woods/xc quad I can I pikd up an 86 for dirt cheap and tor.e it down to frame and starting from basically scratch......the quad came ith a dynatek cdi box. and im thinking about getting a 01 cr250 ignition??? I have to get an after market stator for lights to work??ricky stator??? or what?? im new to the whole building ive ridden and put on after market parts my whole life but never a full build so any ideas???? im in desperate need of them!!!!!!!! thanks
Offline DnB_Racing
« Reply #3 on: November 09, 2014, 02:07:10 PM »
Quote from: tlr7272;45721
start a new topic under your name so you don't jump on someone else topic, and you will get better answeres
Offline DnB_Racing
« Reply #4 on: November 09, 2014, 02:10:11 PM »
Quote from: Tbone07;45713
Ricky stator isn't that bad for stators if you cant find decent OEM they are the next best after oem, I don't like there wiring harness but there stators are decent quality
Offline brook310r
« Reply #5 on: November 09, 2014, 07:37:27 PM »
Thanks for the info ihave stock stator just need a flywheel Honda want way to much for a new one the Ricky stator flywheel is much better price and it is 200 grams lighter thought it might bring revs back to my 310 and it non Pv so the faster it's get to hight rpm the better right ???
« Reply #6 on: November 09, 2014, 10:45:48 PM »
Quote from: brook310r;45727
There are a ton of very good OEM flywheels on here for dirt cheap. You can find one from a forum member.
A lighter flywheel will help you get to the higher RPM's faster I guess, but you'll be more prone to stalling in the corners
Offline KASEY
« Reply #7 on: November 09, 2014, 11:47:09 PM »
I have 2 light flywheels on ebay right now CHEAP try it and if you don't like it you won't break the bank
« Reply #8 on: November 15, 2014, 01:12:31 PM »
Lighter flywheels do allow the engine to rev faster but with less flywheel inertia you also loose rpm faster while under heavy loads like climbing hills or pulling out of corners like Tbone07 said.
« Reply #9 on: November 15, 2014, 03:00:22 PM »
you just need to use the clutch more with a lighter flywheel.
Offline aztecgwynn
« Reply #10 on: November 15, 2014, 03:17:10 PM »
Please do not confuse Ricky Stator to Rick's Stator;
Ricky Stator makes good products and they offer good warranty service,
On the other hand Rick's stator is the co most have bought bad stuff from.
Personally I have used Ricky Stator product before and would use them in the future if I ever needed, but Rick's stator I would rather throw my money in a garbage can because that is all you will do buying that product!!!
I do know Ricky Stator has his flywheels balanced and that is crucial part of any flywheel!
Offline brook310r
« Reply #11 on: November 15, 2014, 03:34:56 PM »
I have a 310 ear with pt mx pipe and v force 3 reeds and 38 mill air striker has lots off tork thought it would bring so revs back to more like a 250 mabye I'm wrong. But I do know the new 800 polaris rush axsi crank is 2 and a half pounds lighter and and it smokes the old one thought it would kinda work the same like I said could be wrong
Offline brook310r
« Reply #12 on: November 15, 2014, 03:36:51 PM »
I have a 310 esr with pt mx pipe and v force 3 reeds and 38 mill air striker has lots off tork thought it would bring so revs back to more like a 250 mabye I'm wrong. But I do know the new 800 polaris rush axsi crank is 2 and a half pounds lighter and and it smokes the old one thought it would kinda work the same like I said could be wrong
