Author Topic: 86-87 seat on 88-89 Frame?  (Read 5231 times)
Offline Anthony0327
« on: November 25, 2014, 12:45:05 AM »
Will this work? Just wondering cause I have a really nice 86-87 seat and about to buy an 88 frame. Would like this to work if possible so I don't have to buy another. Thanks in advance for the help. All you guys are really knowledgable on here and I appreciate all the great info. Thanks
Offline mandom250r
« Reply #1 on: November 25, 2014, 12:58:36 AM »
i use a 86-87 seat on my LRD frame and works just fine. I use the short rear rubber cushions
Offline Anthony0327
« Reply #2 on: November 25, 2014, 01:01:48 AM »
Great. That's what I wanted to hear. In another month or so I'm gonna start my build thread. Just need a few more parts an I can get started finally. Taking way longer than I thought and even more money but I'm sure you all know that with the killer bikes everyone has on here!
« Reply #3 on: November 25, 2014, 11:37:38 AM »
I had issues using a 86-87 seat and latch on an 88-89 stock frame.  The latch setup is different and I wasn't able to use the 88-89 latch on an 86-87 frame.  So I used the 88-89 seat :D
Offline trx250scar
« Reply #4 on: November 25, 2014, 11:56:39 AM »
An aftermarket latch would fix that
Offline Anthony0327
« Reply #5 on: November 25, 2014, 05:31:59 PM »
Hadn't thought of that. You say aftermarket, the ones that eliminate the latch hook all together like the one pumashine offers or lonestar?
Offline trx250scar
« Reply #6 on: November 25, 2014, 05:47:48 PM »
Ya either kind.and I will tell u the old worn out OEM latches cam fail and let Your rears fly right off the Trailer.
Offline mandom250r
« Reply #7 on: November 25, 2014, 05:50:35 PM »
I use a billet HMF latch. Pumashine can sell you a complete kit garanteed to work with your seat and frame though.
Offline Anthony0327
« Reply #8 on: November 25, 2014, 06:03:05 PM »
thats good. I have a really nice seat I want to use. I didn't know if the dimensions where slightly different on each year which would not let the earlier year seats work on the newer frames. After going back an forth I decided to use the 88 frame instead of the earlier 86.
« Reply #9 on: November 26, 2014, 01:45:07 PM »
An aftermarket latch would work - I used an 86 seat with an OMF knob latch on a LSR frame - worked perfectly.
Offline Brian
« Reply #10 on: November 26, 2014, 03:55:07 PM »
Same here, 87 seat on an 88 frame with a Pumashine mount. Works perfectly.
Offline PNWrider
« Reply #11 on: November 28, 2014, 10:09:38 AM »
[MENTION=1]spiritaces[/MENTION] Is the short cushion seat latch for the stock foam height?
