Author Topic: clutch basket removal  (Read 6450 times)
Offline Tador
« on: November 30, 2014, 03:10:50 PM »
I ripped the clutch apart on my 87, the stock basket fingers are grooved pretty badly. I could machine them, but it seemed better to just put a Hinson basket in it. Which leads to this topic, any advice on best method to separate the basket from its drive gear?
Offline DnB_Racing
« Reply #1 on: November 30, 2014, 03:30:00 PM »
you might want to give the Barnett basket with the ss inserts ....have heard all good about them
I was a little disappointed in the billet Hinson, ive got at least 4 on the shelf and on the quad, or I would be buying the Barnett ones
Offline Tador
« Reply #2 on: November 30, 2014, 04:02:57 PM »
No kidding? Are the Hinsons not holding up very well? Maybe I'll must machine the fingers down then and save myself 230 bucks, the quad is mostly stock anyway; 150psi compression and an ESR pipe is about it.
Offline fearlessfred
« Reply #3 on: November 30, 2014, 04:45:09 PM »
My Hinson's have lasted no longer than oem.Filing the grooves out is an option but will only buy you a little time, because of the slop, the grooves will be pounded back in quickly.
Offline Tador
« Reply #4 on: November 30, 2014, 05:25:26 PM »
Right, true. So I'm assuming I need to drill or grind off these rivet heads?
Offline Tador
« Reply #5 on: November 30, 2014, 05:49:17 PM »
Yup! Got it.
Offline Tador
« Reply #6 on: November 30, 2014, 06:15:23 PM »
Yup! Got it.
