Author Topic: Stripping Crankcase Paint  (Read 5556 times)
Offline Anthony0327
« on: December 12, 2014, 02:47:39 PM »
What do you all use to strip paint of the cases if I want to repaint them. My backup engine is in amazing shape without any cracks, dents or wear marks but the paint has been worn off in a couple areas. Would like to re paint it but strip it first. I know I can have it sand blasted but depending on how it looks I might just leave it that natural cast finish also. I have a can of aircraft stripper that I bought but after thinking about it I don't want to use anything corrosive that may eat at the aluminum.  Thanks for your help.
Offline SARON81
« Reply #1 on: December 12, 2014, 03:59:45 PM »
Airplanes are usually made of aluminum.
« Reply #2 on: December 12, 2014, 05:20:58 PM »
yep aircraft stripper +1
« Reply #3 on: December 12, 2014, 05:48:50 PM »
These are lonestar aluminum hubs that I am currently stripping.
« Last Edit: December 12, 2014, 06:42:33 PM by Hawaiiysr »
« Reply #4 on: December 12, 2014, 05:50:24 PM »
Powder coat peeling away.
Offline Anthony0327
« Reply #5 on: December 12, 2014, 06:35:57 PM »
Thanks for the help. I've never done this so I didn't want to mess anything up.
« Reply #6 on: December 12, 2014, 07:58:51 PM »
theres some spray can stuff you can buy at walmart that works just as good as anything. its pretty cheap also. cant recall the name but ill have a look in the garage and let you know what it is
« Reply #7 on: December 13, 2014, 01:56:16 PM »
citrustrip in a spray can is what i used. worked pretty good. paint was off in just a few min.  rustoleum and a few other companies makes a spray can stripper you can get at walmart. i suppose they all work about the same
Offline bholzgen
« Reply #8 on: December 13, 2014, 11:41:26 PM »
Aircraft remover will not damage the cast aluminum.
2002 Roll Design Lobo MX
2002 Laegers CRF450R Hybrid
1985 ATC 70
