Author Topic: Something Im working on.  (Read 24742 times)
Offline mrtwidster1
« Reply #30 on: September 12, 2015, 06:47:17 PM »
Little update here on this project.
Since i now have the bike up and running that this is on, I tried it out. It will work and indeed put out the voltage i need (13V). Yea!!! but... I have to hit 76 miles per hr before the flux capacitor will kick in. HAHAHA  (Just a joke there). in reality about 40 mph.
I need to make a bigger pulley for the drive side about 8 inches. I have sourced the billet aluminum I need and my machinist will put it on the "lathe a runi " and fix me up. Hopefully i will have it completed by the OCT ride at ST JOE.
I will update when I make more progress or if i get a letter saying I am being sued by DeLorean or DOC Brown.
« Last Edit: September 12, 2015, 06:48:36 PM by mrtwidster1 »
« Reply #31 on: September 23, 2015, 10:56:46 PM »
Interesting. Thinking outside the box. I like
« Reply #32 on: September 24, 2015, 12:19:33 AM »
I wouldn't worry about it, Doc is a good guy. What is St Joe?
Offline mrtwidster1
« Reply #33 on: September 24, 2015, 01:11:28 PM »
ST Joe Park in MO. Ride planned there on the 8-10 next month
Offline mrtwidster1
« Reply #34 on: December 05, 2015, 12:42:44 PM »
Little update. Made a larger Dia pulley and installed the matching Kubota regulator/rectifier and I get 13.5 volts at about 25 mph. I will put a sealed battery and make a wiring harness and I should be good to go. Just trying to do something unusual. Like was suggested, I may give the LED a try. I can buy H4 socket Led bulbs to put in my existing light choice.
The light bar came with an old set of Dick Cepeck lights. I may powder coat the cans and use them. They also take the H4.
 I made the light bar so it could be installed/removed in a few min. I will be able to put the white Maire head light on easy.
« Reply #35 on: December 05, 2015, 08:20:43 PM »
My hats off to you [MENTION=123]mrtwidster1[/MENTION] - this is slick!
Offline mrtwidster1
« Reply #36 on: December 15, 2015, 12:20:01 PM »
^^^^^ Thanks
Offline mrtwidster1
« Reply #37 on: December 26, 2015, 09:33:32 AM »
Battery and voltage reg operational. Lights work. Maintains 12.5 volt charge to battery. I will put the electrical through some testing this spring. Once it is proven dependable I will make a proper wiring harness.
Offline Robsessed86
« Reply #38 on: December 26, 2015, 10:05:28 AM »
You have created something very impressive mrtwidster1. You have a creative mind. I'm looking forward to a tried and tested review B/c I may have interest in being a customer if you decide to sell a package to make this work.
Offline mrtwidster1
« Reply #39 on: December 27, 2015, 06:43:28 PM »
I will update after i have used it awhile. If it proves dependable then I will do a full spec write up. Thanks for the interest.
One spot one flood. I will put h4 led bulbs in eventually and try them.
Offline mrtwidster1
« Reply #40 on: December 27, 2015, 06:50:43 PM »
dbl post
