Author Topic: radvalve clamp  (Read 3535 times)
radvalve clamp
« on: January 20, 2015, 07:59:14 PM »
does anyone have a radvalve on thier engine they can take a look at the clamps that hold the rubber boot to the carb and see what size they are. seems like their a gemi brand but im wondering what the size is. it should be stamped on the side. something like 48 or 50 maybe.
Offline jfwyatt1
radvalve clamp
« Reply #1 on: January 20, 2015, 09:31:23 PM »
the clamps on mine say 48mm but they arent original just stainless clamps from the parts store.
Offline Usmoneylover
radvalve clamp
« Reply #2 on: January 20, 2015, 10:22:26 PM »
radvalve clamp
« Reply #3 on: January 21, 2015, 12:12:23 AM »
wyatt thnx for the info. i was figuring they were somewhere around 48
usmoney are those originals ?  reason i ask is because the radvalves that use 38mm carbs use the 54mm gemi clamps. for some reason i thought 250r used a smaller carb like 36mm, there for the clamps would be a bit smaller also im assuming. like around 48 or 50mm ?   im needing a gemi clamp in the 48-50mm range. figured maybe i could get a 250r version and it would be the size i needed
Offline mx250r91
radvalve clamp
« Reply #4 on: January 21, 2015, 02:36:07 PM »
I had one of the gemini clamps break while riding so I replaced them with these heavier stainless ones from McMaster. I think I used the same size for all 3 and just trimmed the excess off the reed valve clamps.
radvalve clamp
« Reply #5 on: January 21, 2015, 04:11:32 PM »
Quote from: udontknowme;49055
Bought the rad valve with the boot/clamps used so I can't confirm if their originals...Never gave it much thought sorry!
