Author Topic: suspension help  (Read 2279 times)
Offline shea223
suspension help
« on: January 26, 2015, 09:55:11 PM »
I just recently got my first R which im stoked about! so ive been going through everything just to make sure everything checks out. anyways i was lifting up the rear end to move the bike around and it seemed like there might be a little bit of play at full extension in the linkage.  farely new to the r so i was just wondering if this is normal or if i should try and tighten it up some?
1987 250r ct 330
suspension help
« Reply #1 on: January 26, 2015, 10:03:43 PM »
Any excessive play is definitely not normal. Maybe have someone else lift the rear of the bike up and down until you find the pivot point that actually has play in it.
Check the swingarm pivot bolt and the linkage mounts
Offline shea223
suspension help
« Reply #2 on: January 26, 2015, 10:17:12 PM »
aight thanks ill check that out. appeciate the help!
1987 250r ct 330
