Author Topic: 2015 lrd/led duner  (Read 28696 times)
2015 lrd/led duner
« Reply #30 on: July 18, 2015, 07:22:00 PM »
Iv heard olive oil helps :rofl:
Offline bnau267
2015 lrd/led duner
« Reply #31 on: July 19, 2015, 12:37:28 AM »
Any oil work.  Even castro 927.  Rem oil for cleaning guns really brings out the colors...
Offline Anthony0327
2015 lrd/led duner
« Reply #32 on: July 20, 2015, 10:47:51 PM »
That's one hell of an engine. Looks awesome. Can't wait to see the finished product
Offline mandom250r
2015 lrd/led duner
« Reply #33 on: July 21, 2015, 07:06:51 PM »
Thanks for the compliments fellas but unfortunately im planning on using this arens frame for now. My mind is still set on a all flat black with carbon fiber parts. Would like to redo it later with a LRD black anodized frame if i can find one. Took this quik pic before i hung it up on the roof as i have no room in my garage for all these projects im working on.
« Last Edit: July 21, 2015, 08:54:06 PM by mandom250r »
2015 lrd/led duner
« Reply #34 on: July 21, 2015, 09:08:18 PM »
Help me beat up on Arlan for some stainless pipes. I was fairly close to talking him into it. I have the raw pipe too. They are fairly easy to care for, a little scotch brute and oil, but it does lose to heat tells, which are the sexy part of a raw pipe, in my opinion. Stainless would solve it.
What happened to the LRD frame? I thought you had one.
Best regards
-Jason
Offline mandom250r
2015 lrd/led duner
« Reply #35 on: July 21, 2015, 09:24:08 PM »
Quote from: 2ndmoto;56282
Best regards
-Jason
ive thought of clear coating the pipe before i use it so maybe it can keep its colors. Dont know if hi temp clear paint or powder coat clear will work.
I still have my LRD frame but i let a buddy borrow it and hes going to get it fixed for me. While he was using it he noticed it cracked a little more so thats one reason i dont want to run that frame with this motor. Other reason is i plan on doing everything black so it would be stupid to powder over my chrome subframe. I tried trading subframes with Higgy but they were not interchangable.
Offline supernutt
2015 lrd/led duner
« Reply #36 on: July 21, 2015, 09:33:35 PM »
I had my bare HPR zilla pipe high temp clear coated before I used it. But it is rusting underneath the clear somehow?  Didn't work out for me but maybe it will work out for you......but you can't beat the look of a bare pipe!!
2015 lrd/led duner
« Reply #37 on: July 21, 2015, 10:50:58 PM »
LED had a shop put hi temp clear on one of their pipes. Never heard how it worked out. I'll keep begging for a stainless.
Offline mandom250r
2015 lrd/led duner
« Reply #38 on: July 21, 2015, 11:08:47 PM »
Quote from: supernutt;56286
Quote from: 2ndmoto;56295
jared skeans1 recommended this http://roadsters.com/gibbs/
Offline Morse250r
2015 lrd/led duner
« Reply #39 on: July 22, 2015, 06:56:26 AM »
there is a guy here in michigan that powders clear onto them, they hold up just fine
88 rb racing duner
Trx 70\'s
Atc 125
Offline mandom250r
2015 lrd/led duner
« Reply #40 on: December 01, 2015, 11:39:32 PM »
Took this off to put on the puma
Offline mandom250r
2015 lrd/led duner
« Reply #41 on: December 01, 2015, 11:41:56 PM »
Replaced with clutch that was on puma
Offline mandom250r
2015 lrd/led duner
« Reply #42 on: December 01, 2015, 11:44:38 PM »
Quote from: spiritaces;61545
looks good!! God bless the quick change
thanks, yea i really like the quik change. this is the first time i take it off and found out its double o-ringed.
Offline mandom250r
2015 lrd/led duner
« Reply #43 on: December 02, 2015, 01:25:41 AM »
i think i like this cover better than the Hinson style cuz right now i have 3 stripped bolts on my CT cover. The cover is real tight i dont see it leaking easily. i started hitting it with a rubber hammer then i gently pried it off with a screwdriver and my fingers
2015 lrd/led duner
« Reply #44 on: December 02, 2015, 08:07:39 AM »
Quote from: spiritaces;61553
thats good,,,,, may have to buy one for my new motor build??? HAHa
Jon I have one and one of Ryan's 89 water pump shaft I may let go.
