Author Topic: Best tool to remove needle bearings?????  (Read 4779 times)
Offline bananas
« on: February 06, 2015, 05:43:34 PM »
Looking for a tool to get them out.... I tried a few things with no luck....
thanks
Offline The Phantom
« Reply #1 on: February 06, 2015, 06:28:47 PM »
If your looking to remove the needle bearings for the clutch lever in the case then a blind hole bearing puller that can be rented (for free)at autozone worked for me.  If your talking swing arm bearings then there are some threads in this forum on those.
Sorry I see now this is in suspension and chassis so now im assuming swing arm bearings...
I split mine carefully with a chisel but I think there was better ways posted.
« Reply #2 on: February 06, 2015, 06:31:46 PM »
Which ones? The swing arms can be a bitch. I usually cut them out. They make a small puller for the clutch actuator arm bearings. I never used one. The shifter drum, can be carefully pried out.
« Reply #3 on: February 06, 2015, 07:35:51 PM »
I'll come up with one, for that TI chassis :)
Offline bananas
« Reply #4 on: February 07, 2015, 07:21:56 AM »
Swing arm.... New Project working on. I tried heating and they didn't move at all. One of the sides just had the housing left and no bearings at all....
« Reply #5 on: February 07, 2015, 12:51:14 PM »
Sounds like its dremel time & a good narrow carbide to grind a slot in one side of that cage housing.
Offline bananas
« Reply #6 on: February 07, 2015, 03:21:24 PM »
Yup........... Dremel did it....
