Author Topic: Need help with pwk carb throttle cable  (Read 3996 times)
Offline c_williamson007
« on: February 26, 2015, 09:56:48 PM »
I just picked up a 38 pwk carb from ESR. After a quick chat with one of the guys over there he informed me the cable they stock for their carb is for a thumb throttle and I'm running the motion pro turbo twist throttle.
After fitting up the carb (intake bell machined by ESR for stock air box) and it fit perfect! I threaded the cable through the cap and SCREECH!! My party train came to a halt.
The brass adjuster on the cap is too small to fit the cable sheath end. Dose any one know the proper part for this aplication? If you have one you don't need maybe we can make a deal. Thanks for the help in advance.
« Reply #1 on: February 27, 2015, 09:52:39 PM »
Call motion pro and order the right cable. The carb is not setup to the cable, it is the cable that is set up to the carb. The correct cable will have a very small crimped end on it. Figure out what twist you have by looking it up on M.P.'s site.
Here is a link to the cables.
http://www.motionpro.com/motorcycle/search/by_motorcycle/0/1989/Honda/TRX250R/Cables+-+Special+App/0/0/0/0/
Best regards
Jason
« Reply #2 on: February 27, 2015, 10:08:27 PM »
Thanks for the info. Just after I made the first post I hit the motion pro site and found the cable I needed. It is #01-0227 and it just so happened a member from the site had just the one I needed
