Author Topic: Time to start...  (Read 9251 times)
Offline michaelgtrx
Time to start...
« on: March 06, 2015, 02:59:09 PM »
Seeing all the build threads on here has got me motivated to pull out my 86 and get it cleaned up and going.  Ashamed I let it get like this....
« Last Edit: March 06, 2015, 08:07:36 PM by michaelgtrx »
Time to start...
« Reply #1 on: March 06, 2015, 03:26:41 PM »
what pipe is that? what are your plans?
Offline michaelgtrx
Time to start...
« Reply #2 on: March 06, 2015, 03:35:33 PM »
Lrd pipe. Plans are get it running for starters. ...trail/dune build from there...I think it's only on its second bore if I remember right. Had a cool head with o ring mod and reed spacer also....
Time to start...
« Reply #3 on: March 06, 2015, 06:00:58 PM »
Any start is a good start. Looks like you have a good beginning. Welcome to the site and ask questions if you have any. Lots of great knowledgeable members here.
Offline michaelgtrx
Time to start...
« Reply #4 on: March 06, 2015, 06:13:26 PM »
Thanks pumashine. Had low compression.  Pulled the cylinder off.  Rings were stuck on the piston. Got one slightly freed. Letting some penetrating oil work for awhile. Bore and piston looked good orherwise...
Time to start...
« Reply #5 on: March 06, 2015, 07:59:11 PM »
Great start! Enjoy the build! Remember, it's therapy. :encouragement:
Offline michaelgtrx
Time to start...
« Reply #6 on: March 06, 2015, 08:02:58 PM »
....go with new, or free the rings and reuse??[IMG]http://tapatalk.imageshack.com/v2/15/03/06/50e9c0c4d39c7768a163be70f142d701.jpg[
Offline michaelgtrx
Time to start...
« Reply #7 on: March 06, 2015, 08:35:47 PM »
And frozen up wrist pin....
Offline michaelgtrx
Time to start...
« Reply #8 on: March 06, 2015, 10:02:43 PM »
Wrist pin freed....
Time to start...
« Reply #9 on: March 07, 2015, 07:36:08 AM »
Slightly rich! The piston skirts look good. Clean up the carbon in the ring grooves, hone the cylinder, new rings, you should be good!
Offline michaelgtrx
Time to start...
« Reply #10 on: March 07, 2015, 02:21:12 PM »
Any tips on freeing up the rings?...in the meantime, the flywheel. ...
Time to start...
« Reply #11 on: March 08, 2015, 08:43:30 PM »
Quote from: michaelgtrx;51131
Does look like there was a threaded end of a bolt bouncing around in there. Is the stator working? One of my Counter balancer bolts broke off and I took it out. Later the threaded part of the bolt came out and destroyed a brand new stator from Honda.
If the rings are just bound up by gum you can use some carb cleaner to get it off. Not seeing it was bound by aluminum in the pics.
Offline michaelgtrx
Time to start...
« Reply #12 on: March 08, 2015, 08:58:05 PM »
Got the rings off.... I can't remember if the stator was working or not.  Going to put the top end back together once I get new rings. I guess I'll be able to tell if the stator is working when I can kick it over....
