Author Topic: diy stripping chrome  (Read 7548 times)
Offline dem3500
« on: March 20, 2015, 08:49:21 AM »
Has anyone been successful in stripping chrome? If so what did you use?
« Reply #1 on: March 20, 2015, 01:08:47 PM »
Nitric acid
Offline dem3500
« Reply #2 on: March 20, 2015, 01:15:14 PM »
Where do I get that at?
Offline oldschoolr
« Reply #3 on: March 20, 2015, 02:43:45 PM »
I just took a clutch cover to my chrome guy to remove some old chrome,  he said the best way is to reverse the chrome process.
Offline Rupp250
« Reply #4 on: March 20, 2015, 06:21:21 PM »
Take it to a chrome shop. Do you want to replate it or just want the 'bare" look?
DUNER -86 250R  Flinstone
Offline dem3500
« Reply #5 on: March 20, 2015, 07:11:15 PM »
I just want to strip it so I can PC it.
« Reply #6 on: March 20, 2015, 09:46:41 PM »
I stripped chrome off a clothes rack with a cattle prod once. Don't know if it would work on quality chrome though.
Offline Rupp250
« Reply #7 on: March 20, 2015, 10:01:15 PM »
Sandblast it and powder away then.
Offline derrick250r
« Reply #8 on: March 21, 2015, 11:14:33 AM »
nitric acid dont strip chrome.It eats the nickel off but dont use nitric if it's metal or you wont have anything left the metal will be GONE!!!.. I use reverse current on my rectifier to get the chrome off. only use nitric when stripping nickel off aluminum. strip the chrome off with hydrochrolic acid.(muractic acid) lt'll take the  chrome off not the nickel. we use a product BM-10 for the nickel it  only eats nickel off everything metal Brass,copper, aluminum ETC. don't  know if you can get that product if not your best bet is blasting it. AGAIN DONT PUT METAL IN NITRIC ACID!!!!!!!!!!!!!!!!!!!!!
Offline jfwyatt1
« Reply #9 on: March 21, 2015, 01:15:11 PM »
Quote from: Rupp250;51918
have done this many times with no ill effects.
Offline fearlessfred
« Reply #10 on: March 22, 2015, 12:06:39 AM »
Quote from: derrick250r;51936
I have used hydroclorlic acid to strip flash chrome and it worked well.use extreme caution if you use it. muractic acid is a fraction of the strength of hydrocloric.
Offline dem3500
« Reply #11 on: March 22, 2015, 09:37:40 AM »
Sand blasting does not remove chrome. Chrome is one of the hardest materials there is. Even the professional sand blaster I use says he can't get it off.
Offline D Bergstrom
« Reply #12 on: March 22, 2015, 03:47:22 PM »
Quote from: dem3500;51963
You don't have to remove it. The purpose of blasting the chrome is to roughen it up so the powder has something to adhere to, then you just powder right over it. The guy I have do all my powder coating does the same thing, blast and powder, no reason to remove the chrome. He says he has done this a lot (powders a lot of chrome off of Harley's) and has never had one part with an issue.
Doug
2004 TRX450R, 2008 TRX700XX
2008 TRX700XX
2005 TRX450R
1986 TRX250R
Offline dem3500
« Reply #13 on: March 22, 2015, 04:09:34 PM »
I want to know how to remove chrome not how to apply powder to blasted chrome.
« Reply #14 on: March 22, 2015, 05:29:22 PM »
Other than sanding it off the only way known is the chrome stripper used by the chrome shops.
