Workshop
Engine and Bottom End
What the hell noise is this now?
Topic: What the hell noise is this now? (Read 10998 times)
BJR88250r
July 20, 2013, 12:37:00 PM »
I just switched out my base to this 86 base everything went well when first started up no noise. Then a couple minutes into running it started with this what sounds to be flywheel noise. Seems to be quieting down but still there. If I take flywheel off and put back on the noise is gone for about 30 sec or so then it comes back. Sounds like it rubbing somewhere but have checked everything over. Seems like you rev it up it goes away dunno. Went from one noise now to this noise. Lol (bearings are good no slop)[video=youtube_share;Az9C0ZPMin4]http://youtu.be/Az9C0ZPMin4[/video]
BJR88250r
July 20, 2013, 12:37:55 PM »
Another one....[video=youtube_share;4CzgGoP2hog]http://youtu.be/4CzgGoP2hog[/video]
Polonda
July 20, 2013, 12:52:24 PM »
The pistons not tapping the dome is it? Did you check your squish with some solder?
BJR88250r
July 20, 2013, 01:19:25 PM »
Yeah squish good little less then .040 . I know it sounds weird but I think it's some how linked to flywheel it never gave me any trouble on old setup. But you take it off reinstall goes away for abit. The sound is coming from there too. Was gonna swap out keyway but I can't get it off this crank. Any tricks to that? Thanx polanda (only seems to make noise at idle) I can't catch a break on engine noises lol
jcs003
Total likes: 44
July 20, 2013, 02:18:25 PM »
maybe a loose magnet on your flywheel???
BJR88250r
July 20, 2013, 03:17:22 PM »
Yeah I was thinking same possibly. Not other flywheel to try though. Just didn't seem to make that noise before attest I didn't hear it. Put stator cover on you can't hardly hear it. Anyone got a 01 stator? Thanx
christph
July 20, 2013, 04:59:04 PM »
I'm not sure I'm hearing the sound you are talking about. So, just a guess, did you check the clearance between the sensor and raised pulse trigger on the flywheel?
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
Polonda
July 20, 2013, 05:24:23 PM »
Did the flywheel get dropped? Check the distance between the pickup and flywheel tab. Do you have a stock ignition setup to try?
BJR88250r
July 20, 2013, 08:31:16 PM »
No I sold the stock setup. Might still have one but I don't think so. I've already checked pulse trigger and raised it to make sure it's clearing the flywheel. Flywheel wasn't dropped that I'm aware of. I just got done running I said the heck with it. After running it for just alil bit the noise stopped go figure. When fully warmed up it was quiet as a church mouse lol. I'll try it in the mourning and post back. Only does it at idle when could or seems to. Could be flywheel I'm thinking cause it goes away when warm. On a positive note this base is quieter then my other one that had a case to bearing issue. The 6th gear def taller in this 86 case allows for some serious top end on the ole lrd 310. Used to rev 6th out quick. The 5th gear feels about the same to me. Thanx guys
bnau267
Total likes: 10
Reply #9 on:
July 21, 2013, 12:56:16 AM »
Not related but who makes that case saver?
BJR88250r
Reply #10 on:
July 21, 2013, 08:56:47 AM »
eBay I found it. My last name starts with a R too so it fit well. Lol
bnau267
Total likes: 10
Reply #11 on:
July 21, 2013, 02:04:23 PM »
Nice! My first name starts with a R. I'll keep hunting....thanks again.
BJR88250r
Reply #12 on:
July 21, 2013, 02:42:50 PM »
Just got done riding again noise was there cold when idle was low but if you idle up noise goes and it seems to be gone fully warmed up. I think it also might be something todo with when you idle cr ignition down low. Or it's a bad flywheel but don't have another to try. If flywheel was bad would it be noisey at upper rpm's too? Thanx
mx250r91
Reply #13 on:
July 21, 2013, 03:49:21 PM »
Take the flywheel off and shake it hard and then twist it by hand rotating directions hard to see if you can hear loose magnets.
BJR88250r
Reply #14 on:
July 21, 2013, 09:30:52 PM »
Yeah tried that cant hear nothing but noise def coming from that area I'm sure of that but flywheel sounds solid.
Workshop
