Workshop
Engine and Bottom End
Question about Sphynx, Puma, Saber-tooth and other big bore cylinders
Topic: Question about Sphynx, Puma, Saber-tooth and other big bore cylinders (Read 4550 times)
Black Sheep
April 05, 2015, 10:14:25 PM »
Sphynx, Puma, Saber-tooth and other big-bore or powervalve cylinders.
Do any of these, or any other big bore cylinders not fit in the ATC 250R frame?
Last Edit: April 05, 2015, 10:38:20 PM by Black Sheep
Hawaiiysr
Total likes: 90
Question about Sphinx, Puma, Saber-tooth and other big bore cylinders
April 05, 2015, 11:43:04 PM »
Yes sir!
Black Sheep
April 06, 2015, 12:14:15 AM »
uhm...ok what ones don't fit
rk88r
Total likes: 8
April 06, 2015, 07:43:13 AM »
I think spark plug clearance is the issue.
Pumashine
Supporting Member
Total likes: 27
April 06, 2015, 09:41:41 AM »
No problem with the Puma
Puma 408,
Puma 431,
Pilot 412,
Puma 431,
Mini-tooth 486
Trx450r
JesseA420
April 06, 2015, 09:48:15 AM »
spark plugs will always be close to frame, but squeezing huge intake tracts between that small area between the upper shock mount and the frame rail is going to be an issue id think.
dave moores new chassis addresses both these issues. i would contact him.
Black Sheep
April 06, 2015, 10:00:31 AM »
I'm building my own frames for big bore 250R/500R engines. Intake clearance won't be an issue. Just curious to what problems the big bore 250R cylinders have with stock frames
Workshop
